Subwoofer Wiring Help
I tried searching but I don't wanna make a mistake...
If I have an amp that is 600 W at 2 ohms, do I match it with a DVC-2 ohm sub that is about 600 W, or a DVC-4 ohms sub? Thanks! |
If it's a single channel amp, then match it up with the DVC-4 ohm sub with the voice coils run in parallel. If it's a 2 channel amp at 600w per channel, then use the DVC-2ohm sub, one voice coil per channel. In any case, make sure the woofer is in a properly sized enclosure for best output and sound quality.
