system install in 06
Old 12-29-2013, 07:34 AM
nikkis06's Avatar
Default system install in 06
I have a 2006 tc and had the bazooka powered sub in it when I got the car with a Sony head unit. I decided to install 2 10s and a bigger amp. I ran all the wires for the amp and now the amp gets power but I have no sound. I also just changed to a new head unit and still have the same problem. I have the hot wire to the battery, a good ground, rca cables, and my remote wire is hooked to the remote wire from the radio. Do I need to disconnect something that was ran to the bazooka sub? I have disconnected and taken it out of the car. Any help is appreciated!
nikkis06 is offline
Old 01-10-2014, 03:18 PM
pbullis's Avatar
It should be working as long as you have power to the amp, a good ground, a good connection to the amp from the head unit, and good connections with speaker wires to the subs. Check all your connections, if you have to, unhook them and hook them all back up to ensure you didnt miss anything
pbullis is offline
Old 01-23-2014, 09:57 PM
mattieg's Avatar
what sony radio is it? Some radios will have to have the subwoofer setting turned on in order for it to work. Make sure the RCA's are hooked up to the pre-out "SW" and not the input BUS on the radio, and make sure they are hooked up to the input on the amp.
mattieg is offline
Old 02-18-2014, 03:19 PM
dc2587's Avatar
^ This. Go into sony menu and enable the subwoofer to 'on' and double check your RCA to sub output. Depending on the amp make sure if its 2 channel or more that it is bridged correctly.
dc2587 is offline
Frustratez
02-26-2015 04:03 PM
greddy05tc
02-20-2015 02:16 AM
Beesh
01-09-2015 06:30 PM
PTUNING
12-11-2014 08:09 PM
TheRedBox
31
12-02-2003 04:53 PM
Quick Reply: system install in 06
