Hvac issue
Hvac issue
So sometime in the last week my radio blew a fuse...whoever owned the car before me left the wires exposed when they did the install. Any who but when that fuse blew (I replaced it of course) my hvac lights don't work. I have no clue on what to do. Any input would be much appreciated!
I guess if I was in your situation I would probably start by unplugging the hvac and plugging it back in to see if that does anything. Other than that I'm at a lost as well.
Does your clock work? Also does the hvac operate on a fuse of its own? Sorry I'm not much of help either.
Hahah!! Oh!! Now I get it. Yeah that video was much needed. I had no idea what you were talking about. Looks like someone tapped into those wires to maybe do an aftermarket something, and they grabbed those wires so they could control when the item would be on or off based on the steering column light toggle, but they clearly did something backwards. Also, you mention that the previous owner "did the install." That's all you said. So what does that mean? What install? And has your lights always done that, or just after the fuse blew? Because if that were the case, then it's still fuse related and you need to check all of them. There will be multiple that play into effect for your steering column light toggle. The radio fuse will have absolutely nothing to do with the fuse that is related to those lights on your hvac.
The part that the previous owner did was the radio install...and basically every wire was exposed. No black tape no nothing.
Unfortunately it isn't much help, but for what its worth, since I installed my system, my left HID headlight only turns on if I turn on->off->on my lights. The initial install isn't what did it, and it wasn't affected when screwing around with any wires to the stereo etc, what did it was when I upgraded a 20 fuse to a 40 from the battery to the 0 gauge positive that goes to the amp in my trunk. To test it, I downgraded back to the 20 (didn't run my sub on it though), and the headlights worked fine again.
If you changed any fuses or wires from your battery to an amp, that may have caused it. Don't ask me how that even makes sense cause I have no idea.
Edit: For clarity, when I say fuse, I don't mean a fuse in either of the fuse boxes.
missing_image
02-07-2015 07:18 PM
cid_mcdp
01-05-2015 02:45 PM
