ABS light, Brake Light, check engine (P0500), Speedo not working
Ok so I lowered my 2006 TC a few days ago to D2 racing coil overs (not that that matters)
However the next day I had the camber adjusted and my alignment adjusted no problem! I went upstate it was fine came home my ABS light went on, later my brake light came on after that my check Engine Light came on now I noticed my speedo isn't working! Took off my first wheel on the driver side front. Got lucky enough and found the line had been freed almost all the way through. So I have to have it replaced. Went to local AutoZone and found my check engine light to be a P0500 and that my speed sencer also needed to be replaced. I'm thinking it's all in the same that it's just the line that was cut I'm hoping someone can shine a light on what they think (Sorry for the bad spelling & may have posted this in the wrong place FIRST TIME USER) |
Yea, i thought the tc would be normal and have a sensor in the transmission but they dont.
The asb wheel sensor is also the speed sensor. Fix that and it should fix all your problems. |
Correct. The tC has no speed sensor in the trans. My current Camry transmission has it, but the tC has a block off plate where it would normally go. The ABS sensor does both functions on our cars.
