ABS light on, Speedo not working..
OK, so my ABS light has been on for a while i havn't had the chance to bring it to a shop but now my Speedo just stopped working..
When I turn the car on the needle moves up and down though.
Where are the abs lines and fuses so i can see if anything is messed up?
_________
_________
If you don't know where the ABS lines are, or the fuses are, I'm guessing you're not up to the task of repairing the problem.
The ABS fuse will be in the fuse box in the engine compartment, but based on what you described, I'm guessing the wheel speed sensors were going bad one by one, which is why the ABS light came on, and now that all of them are broken, the speedometer stopped working too. So probably need new wheel speed sensors all around.
Well I didn't have the stock wheels on i put aftermarket ones on so the tire pressure light stayed on.
However, I put the stock wheels back on but the light still stays on (TPS)
Not sure why but are u saying my ABS and Speedo aren't working because of my TPS?
______
______
check level of dot4 brake fluid.
simply turn off ( reset ) tps by holding button which is inside compartment box for couple seconds.
as somebody said before " If you don't know where the ABS lines are, or the fuses are, I'm guessing you're not up to the task of repairing the problem "/
Electrical Problems?
Greetings,
My 06 Scion XA brake has the following problems: ABS and engine lights are turned on, Speedo is not functioning but, the gas gage is. Cked oil levels and reviewed wiring under and top of engine but all seems fine. I went to two shops but both said that they were not able to receive any codes. The only thing that I did was to changed the charger on the car.The lights were on th already. Disconnected Neg on the battery for 15 minutes to see if it would reset. Engine light came up turned again a few minutes later.
Your input is truly appreciated.
xBSciontist
06-18-2019 03:06 PM
Ferretgrrl
10-15-2018 02:50 AM
VCUBoy714
Scion tC 1G ICE & Interior
01-05-2015 08:46 PM
umnitza
12-01-2014 06:26 PM
