Interior buttons, knobs, and switches...what are they??
Was that tC manual ever posted online?
I have a couple of questions that maybe some of you Toyota people would know... What's the button in the glove compartment for? And what are the buttons in the mirror for? It seems like 3 of them are homelink, or whatever that garage door programming setup is. then i'm guessing the 4th one is auto-dimming and there's a 5th one....? My fiance's Acura TSX has a button that dims headlights reflecting from cars behind you. It makes everything a dim green, I don't like it so I normally turn it off. |
Yeah! I was wondering what that button in the globe box did too.
When its time for an oil change the MAINT REQD light comes on. After your oil is changed, you push that button and it resets! waa laa!
i didn't even see a picture of the button yet. lol. i've heard about it more than once though.
hee hee, i'll take a picture for you then.
It's the self-destruct button.
voilą! :wink:
the button in the glove box has to do with a low tire pressure warning
i also notice that button... and no idea what it is.... my guess would be for the hatch/trunk release lock... but then there isn't a trunk/hatch release lever on the side as other said. on my lexus that button would not let the valet key open the trunk and the push button for trunk release would not work.
That button resets the low tire pressure warning system. If you get new tires then press that button so the system can recalibrate itself to the new tire pressure.
So is the button in the glove box for resetting on oil changes or tire changes?
Kevin |
The car salesman said it had something todo with the tire preesure, but he wasn't sure.
well... don't know what it is.. know what it can become.. NOS! :lol:
Built-in sensors can detect headlight glare from behind and automatically dim the mirror to help keep glare out of the driver's eyes. The infrared map light can project colored light onto the center console. The mirror housing also incorporates Homelink, which allows you to program your garage door opener into the mirror. |
are you talking about the optional auto-dimming rear view mirror?
hee hee, i was wrong. At least im admitting it! The button inside the glove box is for the tires. so where the hell did i read about the oil thing??
Kevin |
Re: Interior buttons, knobs, and switches...what are they??
I have a couple of questions that maybe some of you Toyota people would know... What's the button in the glove compartment for? And what are the buttons in the mirror for? It seems like 3 of them are homelink, or whatever that garage door programming setup is. then i'm guessing the 4th one is auto-dimming and there's a 5th one....? My fiance's Acura TSX has a button that dims headlights reflecting from cars behind you. It makes everything a dim green, I don't like it so I normally turn it off. ok.. button in the glove box is for the tire pressure monitor reset button to use it fill tires with air the corret PSI that is required and push it and it will reset the system but when u push it drive around for about an hour then... the 5th button on the mirror is the maplight mirror if u push it once it is a white light for maps and stuff but if u hold it it changes from white to orange then to a teal and the manual is posted somewhere but im not sire exactly where at.. |
What? I thought that button was for actuating the SCION-COOL-KILL command, which will, upon pressing the button, cause the seat to fold forward with crushing force... allowing you to rid yourself of those pesky passengers!
srry buttons 1-3.homelink 4-autodim on/off 5- 3 color change light |
