my future 05 tc build
All if not most of my parts are going to sourced from ptuning.
Ptuning short block and head.
Custom bc turbo cams
Ptuning rs turbo kit. Upgrade the turbo and injectors garrett gt35r and 1100 cc injectors
Dual 255lph walbros
Ptuning fuel return system
Fuel swirl pot
Fuel pressure regulator
Underdrive pulleys
Hood exit exhaust
25 psi spring
Water meth injection
Haltech ecu
Ngk plugs 2 steps colder
Weapon r intake manifold
Stage 7 clutch masters twin clutch kit
9 lbs fidanza flywheel
Short shifter.
Sparco fighter seat
Sparco harness
Sparco steering wheel
Hrg hub and quick release
Full cage and net
Fire surpression system
Ait wide body kit
Wheel spacers
Upgraded cv axels
Slotted and drilled rotors
Hawk brake pads
Kuhmo track tires
Apr rear wing
Apr front splitter
Apr canards
Carbon fiber hood and trunk
Carbon fiber doors
Mishimoto radiator and thermostat
Ac delete
Bg coil overs
Just finally got my tc a few weeks ago and getting around to letting all of you know what my plans are for this car. And im also going to be using my car as a test bed for new product a plug and play dash digital gauge cluster.
Let me know what you guys think as im trying to make this almost as fast a chris rados tc. I know ill never have that much power without having to redo every single thing.
Dual 255lph walbros
Fuel swirl pot
Underdrive pulleys
Hood exit exhaust
25 psi spring
Haltech ecu
Short shifter.
Sparco fighter seat
Sparco harness
Full cage and net
Ait wide body kit
Wheel spacers
Upgraded cv axels
Hawk brake pads
Kuhmo track tires
Apr rear wing
Apr front splitter
Apr canards
Carbon fiber doors
Ac delete
Bg coil overs
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
