Stereo Question(s)
Old Aug 24, 2015 | 08:58 PM
crimson10tC's Avatar
Default Stereo Question(s)
Hey guys, new here. Couple questions;
I just bought a 10 tC with the base radio and the 6" pioneer sub. I want to upgrade it because its pretty muddy and gets distorted at higher volumes. Anyone know if there is another 6.5" I can throw in the factory box? Or how i could go about using the wires back there to hook up an amp? Someone told me I can just use a line converter with the 4 wires back there and the one wire for the amp turn on, just run a power and ground.
Can someone shed some light?
Old Sep 8, 2015 | 09:43 AM
WildMineTurtle's Avatar
Before spending the money, have you tried changing the audio settings? Like SSP from Neutral to Hear or Feel; or changing the setting from tC to xB or xA? When I got my tC, it was set to Neutral and tC, and it sounded awful, muddy and quiet. But if you change your SSP and car sound settings, they will sound much better. Try this before thinking of spending money
Old Sep 9, 2015 | 12:08 AM
I did. I played with all the settings before hand. Right now I think im just going to live with it and just cross the upgrading road when I blow it out or whatever. The trunk space as is, is kinda small so Im reluctant to put my box back there anyways
Old Sep 10, 2015 | 06:01 AM
JaiBoog's Avatar
quote from Crutchfield-"The Scion stereo system could be augmented by an optional factory subwoofer. If present, it’s located inside the car’s cargo area. The component is comprised of a 2-ohm, 6-3/4" subwoofer powered by a 35-watt amp, and is integrated into a molded cavity to the right of the spare tire. As a result of the integrated configuration and low-impedance design, replacing this woofer is likely not worth the effort. If you want to replace the woofer, you should also replace the amp with something with more power."
probably be better off just replacing the factory radio with an aftermarket, because it will give your front/rear speakers better overall sound with the sub...
there are 6-3/4 subwoofers that can replace the factory sub, brands like Kicker or JL, but you would need to fabricate the connections with the amp into the factory harness...or just get a different amp & sub box setup to fit in place of the factory box...either way, I hear you on the limited trunk/cargo space, good luck with whatever you decide...
Old Sep 10, 2015 | 03:55 PM
62Fender's Avatar
An upgrade won't necessarily eliminate mud. Sub-frequency is limited but demanding. My sub filter is set at 20Hz to 200 Hz which is great for rock. Hip hop might be better at 15Hz to 150Hz (which might require a larger speaker enclosure and or different port size/depth.) Even a matched range between sub amp and speaker enclosure can sound muddy if the artist recorded frequencies outside your hardware's range.
Old Sep 10, 2015 | 08:44 PM
The sub I would be putting in to replace it is a 12" mmats p3.0 with an alpine 750w. It was out of my last car. Hits Hella hard and sounds good with almost anything. Just very large.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
