Think my A/C is on its way out...Compressor?
After a hot-a$$ summer I decided to check the pressure in my system and it looked a bit low. So I put in some refrigerant to fill it up.
I'm not sure exactly what happened but the very next couple of days the A/C started acting up. Cold air would come out for a few seconds, and then what seemed like warm outside air, and then a minute later cold air again. This happens even when the car is traveling at a constant speed. The compressor is also louder and making much more noise than it used to. I can hear whine through the first couple of gears. Seems like its stressed out. All I did was charge the system for about 30 seconds. And it hasn't been hot the last couple of days either. Does this sound like the compressor? 110K on the motor btw. |
The compressor is on its way out especially at 110K. Some have changed just the pulley/clutch assembly and found that the whine goes away however it sounds like you have cooling issues so it's probably the compressor internals itself. Or you could try a professional full refrigerant replacement first to see if you could've made a mistake when charging.
Not sure if I had my head completely up my @ss when I did this but I just looked again and my valve cap for the recharge port is missing. No idea where it went. Possible culprit?
Originally Posted by jnaval
(Post 3917994)
<Bunch of B.S.>
:D |
Do the AC system service with proper shop equipment. You need to evacuate old refrigerant, pull vacuum and charge the proper amount (in weight- not seconds) of refrigerant and possibly some oil. Then go from there.
Originally Posted by Reactor
(Post 3918025)
If you overcharged then HIGH side pressure will be too high. That can make the system shut down.
(Post 3918055)
Originally Posted by Spoony
(Post 3918018)
Don't listen to this guy!
:D |
(Post 3918097)
Ignore this guy, he rolls on Motgei wheels from PepBoys. :lalala:
(Post 3918025)
Agreed, The A/C compressor will turn on and off if overcharged...Those cans you buy at auto zone or O'Reilly is not accurate The shop machine will measure the exact amount of refrigerant in ounces and add oil along with it correctly. |
When the dial is on blue, there is suppose to be cold air coming out?
