the xB has a "rear hatch door open" light, but the
With my wife's xB, if you open the "trunk" hatch door, the little "open door" red light turns on. This prevents our alarm from arming because a door is open.
With the tC, on the other hand, when the "trunk" is open the car doesn't recognize a door being opened; so whenever we're taking groceries in and out of the house, the car's alarm will arm.
Does anybody else's tC's "open door" light in the dash turn on when the hatch is open?
Why does the xB have this feature but not the tC? (I've heard that theifs will break into a hatchback via the hatch because it won't set off the alarm... unless your motion sensor senses the movement, it'll set off the alarm)
when you open the hatch from my tc, the "open door light" does turn on on the dash. it won't let you activate the alarm or lock any doors. i noticed it several times when i open my hatch to get something and i close it, and when i try to lock my doors, it won't work because the hatch isn't closed all the way yet.
I'm a little confused, because if my hatch isn't shut, the open door light comes on. It's a third door, so that makes sense.
Saved me once when I started driving and noticed the hatch wasn't properly closed (only because of the light)... one of the few times I actually have passengers... and yes, they shut it improperly :sigh:
Originally Posted by trdtcpr
well at least my tC does not arm the alarm automatically so I don't get what you're saying or is it that you have an aftermarket alarm?
What are the odds that the installers disabled my "open door" light function? Should I question them first or take it to the dealer and have them fix it? Advice?
where is the switch located for the rear hatch that sends the open door signal to the dash? I have a 2011 XB that had a left rear tail light and rear fender repaired. Shortly thereafter the open door signal began to light up. The shop said it is the sensor and wants to charge me for replacing it, even though it did not start till after they did the repairs.
Administrator
Administrator
"where is the switch located for the rear hatch that sends the open door signal to the dash? I have a 2011 XB that had a left rear tail light and rear fender repaired. Shortly thereafter the open door signal began to light up. The shop said it is the sensor and wants to charge me for replacing it, even though it did not start till after they did the repairs"
I believe it is located in the Middle of the Rear Hatch Lift Gate under the Handle. At least that was where it was on my 2006 xB. On this pic, take a look at Part # 10:
Ferretgrrl
10-15-2018 02:50 AM
VCUBoy714
Scion tC 1G ICE & Interior
01-05-2015 08:46 PM
