Brake creaking fix
Old 07-23-2011, 09:44 PM
LostCause's Avatar
Default Brake creaking fix
Hi guys,
For a long time ive been having trouble with my passeger side brake. At low speed and full stop my brake always had this annoying very noticable creaking sound. The kinda souns that makes you want to find the nearest wall and just blow your car right thru.
Anyway ive found this on the net and it was actually quite usefull, its for GM vehicles but it worked the same for me.
Youll need:
  • Silicone grease for sliding pins (might as well do them while your at it)
  • Silicone spray
The rest is self explanitory, hope this helps some people who may have the same problem
Print Close Window
Tech Tip: GM Malibu, Alero and Grand
Am Brake Creak When Brakes Applied
Some GM vehicle owners may comment on a creaktype
noise when applying the brakes. It is usually heard
only during slow speed braking.
7/23/2009
By Ed Dorowski, ALLDATA Editor and Jeff Webster, ALLDATA Technical writer
Some GM vehicle owners may comment on a creak-type noise when applying the
brakes. It is usually heard only during slow speed braking. If this condition exists, it
should be able to be duplicated when the vehicle is not moving by depressing the brake
and listening for the noise from the wheel-well/caliper area. The noise may be caused by
a caliper piston-to-seal interface issue during braking. If the caliper is removed and the
piston is pushed back, the noise may be eliminated. This is usually only a temporary fix.
To correct this condition, lubricate the entire circumference of the seal at the caliper
piston interface using Kluber Fluid as described in this Tech Tip.
Applicable Models
1999-2003 Chevrolet Malibu
2004 Chevrolet Malibu Classic
1999-2004 Oldsmobile Alero
1999-2004 Pontiac Grand Am
Parts Information
89022161 Kluber Fluid
Important: The service kit consists of a “one-time use only” bottle which will service
Printer Friendly Page 1 of 3
http://www.brakeandfrontend.com/www/...rFriendly.aspx 7/29/2010
one caliper.
Repair Procedure
Review safety procedures in ALLDATA Repair before beginning.
DO NOT REPLACE CALIPER.
1. Remove the wheel, then reinstall two lug nuts to hold the rotor against the bearing
surface. This prevents dirt and debris from lodging between the rotor and bearing hub
mating surfaces which can cause rotor “wobble” or lateral runout (LRO).
2. Remove the bottom bolt from the caliper assembly without disturbing the hydraulic
system.
3. Swing the caliper assembly up so the
caliper assembly is facing upward (Figure
1).
4. Thoroughly clean the piston boot with
GM-approved Brake Clean. Pay
particular attention to the area where the
boot interfaces with the piston.
5. Using compressed air, dry the
piston/boot area.
6. Remove the cap from the tip of the
bottle and carefully insert the tip, P/N
89022161, between the boot and piston,
inward of the piston boot groove (Figure
2).
7. From the top side of the piston
(reference diagram), inject the lubricant.
With the caliper in the tilted position, the
lubricant will flow down and work its
way around the entire circumference of
the seal. Let the caliper body assembly
remain in this position for a minimum of
two minutes to allow for the fluid to
completely work its way around the seal.
8. Push the piston into the seal to ensure
the lubricant is on both the piston and
seal surface.
Important: Excessive fluid could appear
as a failure and lead to a comeback. To
prevent unnecessary future repairs, it is
important to only use one bottle per side
and make sure excess fluid is wiped
away.
9. Wipe away any excessive fluid.
10. Reassemble the caliper to the vehicle. Tighten the caliper bolts to 23 lb-ft (31 Nm).
11. Repeat Steps 1 - 10 on the opposite side of the vehicle, if necessary.
12. Pump the brake pedal to push the caliper piston back into place.
13. Reinstall the wheel and tighten wheel nuts to specification.
14. Road test the vehicle to verify repair.
Ed Dorowski has 19 years of Domestic and Import dealership and independent shop
experience as a service consultant, ASE Certified Master Technician, Nissan Certified
Printer Friendly Page 2 of 3
Master Technician, & California Smog Test & Repair Technician. Jeff Webster has 20
years of experience as a writer/editor.
2009
ALLDATA LLC. All rights reserved. All technical information, images and
specifications are from ALLDATA Repair. ALLDATA is a registered trademark and
ALLDATA Repair is a mark of ALLDATA LLC. All other brand names and marks are
the property of their respective holders.
Brake and Front End | Copyright © 2010 Brake and Front End All Rights Reserved.
Printer Friendly Page 3 of 3
LostCause is offline
Old 07-23-2011, 10:34 PM
usafscion's Avatar
thanks for the post.... i'm also having either this problem or my caliper is getting stuck... also I went to autozone and got the little metal pieces that goes in the bracket and where the pads slide and got the kit it was $9.. got some grease for the guide pins and will hope this will solve the problem if not they have the calipers reconditioned for $55... good luck man.. hope you fixed the issue..
usafscion is offline
Old 07-23-2011, 10:43 PM
LostCause's Avatar
Hope it helps man, been driving around today and so far so good these couple of days ill monitor it see how it keeps up.
Man i wish i had the option, dealerships here have nearly nothing for scions, napa etc also rarely they only have parts that share the same of other toyotas, toyota mechanics here wont even touch scions.
Old 07-23-2011, 10:53 PM
usafscion's Avatar
just hoping i didnt warp the freaking rotor... its basically new...so hoping to have the fix this week or else I need to change the caliper... at least its easy and cheap fix...or at least relative to other ____ that could have happened. lol..
thanks for the info thou..
Old 07-23-2011, 11:57 PM
LostCause's Avatar
Lets just hope you have the cheapest problem to fix
Old 07-24-2011, 04:15 AM
amp0804's Avatar
Anti-Seize for guide pins and mounting bolts and Disc brake grease on the brake pad shims and all future squeaking will be eliminated.
amp0804 is offline
Old 07-24-2011, 07:05 AM
LostCause's Avatar
Well this procedure is more for a creaking noise, not disc squeeking. If youd stop the car completely and then push on the brake youd hear a horrible creaking sound when pressing and depressing.
But what you posted will def get rid of any squeeking
Old 07-27-2011, 02:22 PM
LostCause's Avatar
Just an update:
Been driving around allot during the weekend, allot of stop and go traffic here and the procedure seems to be holding out.
No creaking what so ever
Old 07-27-2011, 04:38 PM
usafscion's Avatar
not to steal the thread but to add info to help out... I was getting the brake noise as I was driving and when on the brakes no noise... so I took my break apart and lubed the guide pins... my ride is 07 with 50K and the guide pins where dry like a ****... also bough the guide metals that go where the pads slide in for 9.99 at autozone..... break is great no noise...
good luck guys..
Old 08-02-2011, 12:44 AM
othater's Avatar
Does the rubber boot just pull back or is there a ring holding it on?
and just regular silicone spray for lubrication. How much to spray in the boot?
Thanks
othater is offline
mc1114
Scion tC 1G Aero & Exterior
04-23-2020 10:34 PM
xBSciontist
06-18-2019 03:06 PM
sciontcguy15912
03-21-2015 03:58 AM
CPL_Radar
03-05-2015 05:42 AM
MosFed
12-27-2014 03:24 PM
Quick Reply: Brake creaking fix
