Dezod Stainless Steel Brake and Clutch Lines: HOW TO and REVIEW
Buy from Dezod themselves
http://www.dezod.com/
I bought mine from mengmotorsports but id advice buying from them, all you will get is headaches with your order from horrible customer service.
thanks for the guide, I just install my dezod line today.
just 1 question. The 10mm nuts at the feeding line was not able to in to the new brake line all the way.
Looks like you wasn't able to get it screw all the way in too. Should i worry about it?
If she is tight and not leaking, then no worries.
for the life of me i could not get the feeding line off even with locking pliers wd 40 and pb blaster. both me and my friend tried to get it off but we stopped before the bolt got really stripped. any suggestions for us to try?
For those of you having trouble with the install. I have a small update. This past august, I had my transmission out of the car and was finally able to do the stainless steel clutch line. My uncle's buddy let me borrow this:
http://www.mechanicstoolsupply.com/3..._p_21221.html#
Its called a crow's foot but I called it a god send. I can not express how badly I wish I had this tool when I was doing the brake lines. It made unscrewing the feed infinitely easier.
I would say this tool is an absolute must have for the project.
I wish I had a pic to help explain, but basically the tool snaps on to the end of a socket extension. The opening in the hex shape allows you to pass the feed line through and then slide the tool over the screw. You basically then have almost a full box end grip on the bolt making it a snap to torque loose.
for anyone looking to tackle this project, i picked up a flared wrench set for cheap to use instead of the regular open socket wrenches and the flared set worked wonders. just had to let the pb blaster soak in for a few minutes and then they came undone with no effort at all.
NonStopTuning
Jun 29, 2015 07:42 PM
ERZperformance
May 13, 2015 11:36 PM
CrowJenkins
May 4, 2015 04:52 AM
kdanie
9
Jul 12, 2005 01:12 AM
