Ground Control Coil Kit + Koni Yellows
Scionetics
My current setup right now is OEM Shocks and Tein S techs. Its about time to change my suspension due to cracking noise from the front and rear (probably wore out struts). I was wondering if anyone of you guys have this setup right now and how it is? The ground control kit can get me just a tad bit more lower than the S Techs to get me gapless.
I heard that setup works really well for civics. Not to sure about the tC though. I was thinking about for with that setup before I got my coilovers. Saw one other guy that I this setup.
Coilover sleaves are the cheap way out. Don't do it, they will make poping sounds over bumps, and be really bouncy. Had them on a civic I bought, got rid of them within a month...just buy the TRD struts off of TRDsparks...you will be much happier in the long run.
Check out some NICE coilovers like KW. We have them in stock, SUPER nice build quality and screamin pricing for what they are.
http://www.dezod.com/pd_kw_variant_2_coiloverstc_05.cfm
Originally Posted by Sauce
Paul I checked out those coils but from the specs you gave its not enough drop for me. But the rest of your site is great
Lowering much more than 2.3", I would not recommend on a shock at all. You may want to consider hydros or air bags then
If ya want to go low I would suggest get B&G's since they can go pretty low. Stick with true coilovers and not the sleeves. I agree with paul since if ya want to go low low then go with air bags.
Scionetics
Scionetics
Well your on stocks correct?? Are you going for any performance or just for looks?? If 3 inches is what you want, then go with some true coilovers.
Scionetics
Originally Posted by Aroddalobster
lolz performance over looks? you're running s-techs on stock shocks and 18" tenzos.
Now for the Koni Yellow/ GC question you have, that is the #1 budget choice for Honda/Acura auto x'ers. The Konis are a great performance shock which can be pretty much customized to whatever application you want it for. You can send them off to get the body shortened, the dampening to be reset for higher spring rates or different track surfaces. They are a great budget suspension. Also, whoever you buy your ground controls from you can also specify your desired spring rate. Take note the Yellows are only recommended to hold a 600lb/in spring.
I just re read your posts and it seems that you care most about your drop than anything else. So I would recommend some very cheap low grade coilovers with adjustable bodies. The D2's, K-Sports or Megans are all very cheap and will allow you to slam your car how you want it. If you want to get serious about performance I would recommend you the KW Variant 2's that Paul suggested, or doing a custom koni/gc setup. The latter of which takes a little more suspension knowledge to get a good setup out of.
Scionetics
P.S. I am on a budget
