Hawk HP+ Squeaking
Old Aug 11, 2009 | 07:55 PM
tCtCtC's Avatar
Default Hawk HP+ Squeaking
I just got these installed and they didn't squeak at all, until the next day. Now they squeak like no tomorrow. Is there any fix to this?
Old Aug 11, 2009 | 08:39 PM
Carlanga's Avatar
some people take them off and scrape them on the ground to get rid of any glaceing
Old Aug 11, 2009 | 10:08 PM
Rexpelagi's Avatar
Did you bed them in properly? If so, it's just par for the course. They are aggressive high performance pads that are designed for track days and autocross but are still able to work at lower (street) temperatures. However, they squeal as a by-product.
I would not recommend scraping any sort of friction surface on the ground, that sounds like a horrible idea. It may get rid of the squealing but it could be horrible for performance especially if the ground leaves deposits on the pads.
If you didn't bed them in properly then bed them in properly.
http://www.hawkperformance.com/performance/burnish.php
  1. After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
  2. Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
  3. DO NOT DRAG BRAKES!
  4. Allow 15 minutes for brake system to cool down.
  5. After step 4 your new pads are ready for use.
Old Aug 11, 2009 | 10:13 PM
purpled_out_tC's Avatar
excuseeee, what is "drag brakes"? but yeah i agree: scraping brake pads against ground+probably not a good idea=i wouldn't recommend/do it.
Old Aug 11, 2009 | 10:15 PM
Rexpelagi's Avatar
Dragging the brakes (or you could say riding the brakes) is when you are driving with the brake pedal partially depressed so slight brake pressure is being applied. Basically, if you aren't doing one of the bed-in stops keep your foot off the brake.
Old Aug 11, 2009 | 10:18 PM
oh yeah, okay then i'm tracking. i hate when people ride their brakes and i'm behind them. i move around them as soon as i can.
Old Aug 11, 2009 | 11:00 PM
mattieg's Avatar
just curious do you have new rotors or did you got them resurfaced?
Old Aug 11, 2009 | 11:50 PM
tCtCtC's Avatar
they were resurfaced, and i they were bedded properly
Old Aug 12, 2009 | 12:02 AM
Rexpelagi's Avatar
If they were installed and bed-in properly then there's nothing you can really do. Hawk HP+ pads along with some other brands in the same category just squeal from time to time. They may squeal for a few days and then if they get hot they may stop for a few days.
Old Aug 12, 2009 | 12:03 AM
tCtCtC's Avatar
Hmmmm okay.
It's just annoying cause they squeek more than my old pads =/
Old Aug 12, 2009 | 12:08 AM
ack154's Avatar
My Axxis Ultimates have squealed all along. You kind of make a sacrifice in performance for noise. Especially with the HP+.
Old Aug 12, 2009 | 12:13 AM
tCtCtC's Avatar
Looks like I'll be getting OEM pads my next time around. They squeal even MORE than my Axxis Deluxe's.
Old Aug 12, 2009 | 12:18 AM
Rexpelagi's Avatar
Hmmmm okay.
Hawk makes another street performance pad, the HPS. It's designed for light autocross use and street use. Here's some descriptions from raceshopper.com. (http://raceshopper.com/hawk_brake_compounds.shtml)
Originally Posted by Raceshopper.com, regarding HPS Pads
Compound Description
Hawk HPS -
High Performance Street
Street Use
Hawk Performance HPS compound provides advanced braking characteristics to enhance your driving experience. This unique compound combines the safety and quality of Aerospace design partnered with the braking technology of motorsports.
Features:
-Extremely low dust
-Higher operating temperature range compared to Original Equipment.
-Much improved braking over O.E. (Approx 20%)
-High friction/torque hot or cold
-Gentle on rotors
-Virtually noise-free
-Long extended pad life
Originally Posted by Raceshopper.com, regarding HP+ Pads
Hawk HP Plus
High Performance Street PLUS
Race Worthy
Street Use/
Limited Track Use
Hawk Performance HP PLUS compound can take the heat at the Track and get you home safely without having to change your brake pads in and out. This compound was designed for the serious street and autocross enthusiast. Warning! Due to the dramatic friction levels produced by this product to achieve "race-level" braking; rotor wear, noise, dust, and pad wear may be increased.
Features:
-Extremely high friction output
-Race worthy for autocross
-Race worthy for club racing events
-Elevated temperature resistance
Note the comments about noise. The HPS is a low dust/low noise performance pad. The HP+ is a much more aggressive pad for people who spend time on a track or an autocross course.
Old Aug 12, 2009 | 03:10 AM
tCtCtC's Avatar
im just gonna ride these out until i either cant stand it or they wear out
scotttie17522
Feb 23, 2020 08:38 AM
Andreas24
Sep 15, 2015 02:10 PM
drobins27
Jun 30, 2015 01:57 AM
tCformee
21
Aug 10, 2005 12:58 AM
Riobi
Jan 19, 2005 01:42 AM
