Official Rokkor Tuning Coilovers Thread
#603
so i put my rokkors on about 3 weeks ago, and im maxed out in the front and have 5 threads left in the back. my front passenger wheel has some negative camber on it, but my front driver has a pretty good amount of positive camber on it, so my wheels are like this..../ /------/ / anyone know how i can fix this issue?
besides paying 80 bucks for an alignment
#604
Lol i had the same problem. Getting an alignment is the only REAL fix.
But, what worked for me was buying a camber bolt and installing it on the wheel with positive camber. (all the way negative)
I followed JeremyDoc's DIY here on the forum!
#605
But yeah, I guess camber bolts would be your option after that. They are like $20 on Ebay if I remember for two.
#606
#608
Anyone had problems getting their alignment back to spec while maxed on the rokkors?
I noticed a couple posts up about the camber bolts for up front. My front tires seem to have the same wear, so I shouldn't have to worry about that, unless they are needed to correct negative camber. I just don't want the alignment shop telling me I need this or that when no one else has had problems.
#611
I've done it twice now and still the same thing. There's no ride quality issues or anything awkward with that side though. If anything i might have a blown coil because that side does make a knock noise over the smallest bump. But if its over a regular sized bump or speed bump there's no issue.
#612
As for me. Im goin lower eventually but heres where my daily sits!
#613
#614
I had the same issue with my car. Its a fairly easy fix; if you pop your hood, look at the top of the coilover, there should be a rubber piece in the middle, take that off and youll see a hex bolt. Best results would be to get someone to tighten it using one of those air guns (blanking on the name), tighten it yourself and it comes loose again after a week. The reason being you need something fast enough to spin it against the coil over or else it will come loose again.
#615
just about two years on these coilovers been through snowy winters n slammed as low as they can go "unmodified" an still holding up, but gonna be gettin new coilovers soon! but definitely for the money it was well spent cant complain.
#616
Sent from my I727 rocket on Marz! @_@
#617
@mxyooji, thats sucks fa real, and the whole vibration when when using the a/c sounds really odd to me. but I can only speak for myself as I did when mentioning my experiences with the coilovers. but im not one to just throw them on and never check up on them maintience wise also from time to time especially after goin through winters. not saying you didnt. but just generally speaking, but hope ya get ya situation figured out tho!
#619
Hey everyone! i have a 05 tc with trd springs but plan on stancing it this summer with nin inch rims with a decent stretch and new coilovers, after reading through the comments id figure id ask a quick question... i am rocking a wildwood big brake kit on the front wit spacers to fit the calipers( only on the front).... would this be a problem if i plan on lowering it till like 3 notches are left? let me know!
