Progress or Hotchkis
Which one is better? The Progress sways? Or the Hotchiks sways? I only need the rear, and I dont really know which one is better, so I wanna see what you guys think. Any thoughts, opinions, and experience is appreciated. Thanks
There is no question, if you dont want to change the front, dont get the hotchkis. The hotchkis rear is way to stiff to run with a stock front sway bar. The car will be too prone to oversteer on you if you do.
If you want even less body roll, dont mind losing more independence in the suspension, then hotchkis is a good choice. For street use and a little autox every now and then, you are probably better off with a progress or trd rear bar. |
yeah go with the Progress rear sway it was designed to work with the stock front sway bar, and you cant buy the hotchkis sways seperate anyways.
O OK, thanks guys
glad i came across this thread i was about to buy the hotchkis kit springs and say but looks like i wont be sense i dont wanna change to front sway.
