should i get a camber kit with my tein Stech springs??
I just got my TEIN stech springs but was told that i should also get a camber kit to save my tires. is this really needed? if so...where can i find camber kits for the scion tc? my friend got the same springs but without the camber kit...and his ride seems to be doing ok. any help would be appreciated thanks!
if you rotate your tires on a regular basis you should be ok.......like every 2500-3000 miles, and if your running directional tires, dismount them and rotate them cross wise, a good tire shop should know what your looking to so, i did that for a year or so and did not notice any abnormal wearing issues, it also depends on what type or tires and size of rims your running, if your running the stocks you should be ok, but if your running 18 and up and wider, you may have issues, (more contact patch).......anyways i think you get what im eluding too.
You will def need to have it aligned. The camber is horrible and will wear on your tires. I lowered mine in December and jsut now had mine done...SOOOO much better. Now my wheels are straight. I took it to the dealer and had it done...all for $70.
correct me if i'm wrong...but i believe the tein Stechs will drop it 2inches
another question for you guys though...i'm been searching online for camber kits. i also went to mcgeorge, but they old sell the rear ones. would i only need to do the back tires? or should i do the front as well. i just got my springs put on yesterday and my back tires are leaning inwards quite a bit...i'ma get my camber soon to fix the problem...
Originally Posted by hahaitzskippy
stechs isnt low enough for cambers.
dunt waste your money on camber unless ur gonna tune ur car for a race on a track or something
how much did it cost through Toyota?
