should i get a camber kit with my tein Stech springs??
yes i noticed that my tires leaned in right after the install. but i did take my car to the dealer the other day for an alignment and now my tires are straight. cost about 80bux. so they put on the camber kit for me? i'm guessing once the tires are straight, i won't have any tire wear issues....correct me if i'm wrong...
Originally Posted by Munch
You're gonna need a camber kit. Your tires will be leaning inwards on the top and outwards on the bottom (Neg camber). I lowered my car 4 inches and the camber was real bad.
and you got TEIN S-TECH that can drop about 2" from front to rear DAMN! you really need a CAMBER KIT, you will see soon that your tire thread wear is not really the same as on the front.... except if you dont drive too much, i think you dont need to have a camber kit but if you drive a lot, i recommend to ya a camber kit cuz it helps to align you rear tire as like a stock before and it helps also to have same amount of thread wear on the tire at the front....
peace!
peace!
Originally Posted by lvnurs9
Originally Posted by hahaitzskippy
stechs isnt low enough for cambers.
dunt waste your money on camber unless ur gonna tune ur car for a race on a track or something
Originally Posted by TurboCustomz
The S-techs on the tC are a 2 inch drop. Tein comes with a lifetime no sag warranty, so if yours dropped more then a 1/4 inch after you installed them, either you need to send them back, or you put them on wrong. I've had my s-techs on my car since it had about 80 miles on it and I haven't noticed any uneven wear on my tires. Also, we are a regional dealer for Tein and I've installed a lot of S-techs and never needed to install a camber kit with them. They are really nice springs and the ride is very close to stock.
The drop is as follows
2.4" Drop Front
2.0" Drop Rear
more then 2 in the front....and regardless of the drop and how much it settled the camber was really off. It doesnt take a genious to figure that out.
And FYI- My 10,000 miles on these springs dont touch your 80 miles....with a drop over 2inches you are going to see a camber. If you dont I guess you are just the "lucky one" that or cant tell....mine was incredibly obvious. If I thought you could really see from the pictures I would post them for you.
I rest my case and there really isnt any point in quoting my thoughts again as all I was saying was that if you have a camber issue...take it to the dealer and for $70-80 you can have it aligned and fixed.
Here's another newbie question:
The question in this post asks about camber kits for cars w/ lowering SPRINGS, what if I were to buy coilovers instead? Would this still be necessary? I also understand that the lower you um...lower your car, the higher need for camber kit...so could one say that if you're only lowering around 1.5 to 2 inches, it wouldn't be as necessary as the guy who lowers it 3 or 4 inches?
Also, which bolts would i need b/c i know they have a selection for however much it needs? Here is the link to all the bolts and how much they adjust up to.
http://www.trdsparks.com/install/tCFWheelAlignment.pdf
TheTripleC
Jan 4, 2015 06:46 PM
fluxingnation
Dec 26, 2014 04:28 PM
