18x9, 225/35/18 hyperblack tork revo on tein stechs???
18x9
on 225/35/18 all around... will this fit on tein stechs? rolled fenders?
this guy has 18x9 245/35/18 all around on coil's tho > https://www.scionlife.com/forums/viewtopic.php?t=181270
Originally Posted by tC9o9
225 will be stretched on a 9" rim, if you like it then its a good fit.
Thanks tc9o9 .. But how do you think the handling might be and how long will my tires last. Is it even safe to be stretched?
stretching isn't the safest thing in the world because you're basically putting more tension on the sidewall, however i know alot of people like it for the look. As far as performance goes, you're better off with a straight sidewall and no stretch (at least from what I've seen) and you're tirewear all depends on your toe and camber
and it all depends on what tires you get and what not, as long as you dont have alot of toe, which can be adjusted you should be fine, camber doesnt necessarily eat away at your tires.
I got a set of hp evo hyper silver chrome lip 18x8 and 18x9 225 40 18 up front and 255 35 18 in the back, check them out. I ordered a wheel and tire package from wheelfire.com , they cam fast and i got a great deal. I am wondering what drop i should do because if it gets to low i will rub because of the 18x9 in the back.But i want it to sit as low as possible?? Any suggestions would be great...
Also running a 225 is streatching to much that cant be safe be careful with that.
I may go with the TRD lowering system???
http://www.wheelfire.com/scontent/Wh...224&CheckFit=1
ya i know 18x7.5 or 18x8 is the perfect size but i wanted to take my scion to the next level and let me tell you it looks soooooo good.I will post pics as soon as my girl gives me my camara back
18x8 i agree is the best size
