Low Tire Pressure On/Off
Old 10-24-2017, 01:55 PM
digdeep0169's Avatar
Default Low Tire Pressure On/Off
I recently picked up some aftermarket 17" wheels. got the tires pumped to 35lb... low tire indicator comes on... i try to reset it... won't turn off.
Down the road if i hit a bump, the low tire indicator blinks, then turns off. this is a continuous cycle...
Last edited by MR_LUV; 12-06-2017 at 04:47 AM. Reason: Moved to Correct Forum by Moderator
digdeep0169 is offline
Old 10-24-2017, 02:55 PM
J_Leon's Avatar
Maybe you need to do a Reset:
1-Turn ignition ON. If the pressure light comes on, press the Reset button (in glove box)and release it.
2-Press and hold the tire pressure reset button until the low warning light blinks three times.
3-You might have to drive for a bit for the complete reset, I've done this a few times but in my case I didn't have to drive at all.
Hope that helps!!!
J_Leon is offline
Old 10-26-2017, 07:32 PM
Thanks J_Leon. I've tried the reset button in the glovebox... but it doesn't seem to help. Now... the tire pressure reset button... i haven't tried this... didn't know it existed... but i will certainly look it up.
