Need advices on Wide tires..
OK, I have a 06 tC. I had a wide body kit install because the body was damaged and repainted and I'm running with 38 mm spacers and I'm buying new rims and tires.
And want to get wide tires to cancel the spacers and have better grip just need help finding perfect measurements. ____ |
I’m in the same boat did you ever find any info out? I’m all stock and want the wide tire look
Wide body and spacers .
To eliminate spacers of 35 mm you have to count that your original ET its 45 ... That means that you CORRECT THE POSITION with the spacers ( you did the position of ET10 ) but center of pivoting point of the wheel its now totaly out of articulation and your tires has now diferent shift angles than it should ... the right thing to do its changing for aftermarked wheels with a correct ET ... ET 45 changed to weels with ET - 35 mm and you reach the right angle in the bends ... Normally the angles of wells are diferent / (Ackerman's principles) because inner weel had to make bigger turn ( bigger angle) than the outside wheel and the inner wheel has to follow less track in the bend ! ... changing the ET + to ET- push wheel from OME position - toward outer fender arch ...
