Scionlife.com
Scionlife.com (https://www.scionlife.com/forums/)
-   Scion tC 1G Wheel & Tire (https://www.scionlife.com/forums/scion-tc-1g-wheel-tire-1646/)
-   -   Need Help... is +30 offset on a 7 inch wide rim doable??? (https://www.scionlife.com/forums/scion-tc-1g-wheel-tire-1646/need-help-30-offset-7-inch-wide-rim-doable-134314/)
TCpete 04-15-2008 11:18 PM
i got an idea brewing on some rims and they are 1? x 7 with a + 30 offset .... was wondering if its doable and will clear the brakes.... anyone?? is that to low of an offset to use safely for DD and possible track use??
Ro_Ja 04-15-2008 11:27 PM
I don't see why it wouldn't work. It'll only come out ~0.6 inches from the stock wheels.
1_kLEan_tC 04-16-2008 03:28 AM
Dude....30 will work...i'm going out to 29et...
nebster 04-16-2008 05:23 AM
yep you'll be fine pete but i don't suggest a 25mm spacer if thats what you're thinking
HKSpeed 04-16-2008 06:39 PM
it'll fit fine for track and dd use.
TCpete 04-16-2008 06:44 PM
thanks fellas.. off to roads to pick up some new shoes.. LOL at ur avy HK
1_kLEan_tC 04-16-2008 07:47 PM
I would never run 25mm spacer...I wont run any more than 5mm.
satoman44 04-17-2008 12:09 AM
i'm running 17x8.5 et+32 for daily and autocross. however, if you plan on running 245's or higher, you have to roll your fenders and run negative camber out of spec. i'm running a lot of negative camber so i don't rub on every little bump.
TCpete 04-18-2008 12:11 PM
no i dont plan running such a high width of a tire... most the rims in this offset im looking at are 29-35 offset in 7.5 or 7 inch... 16's and 17's... ive only once considered an 18 but i knew it was to heavy of a wheel for DD fun...
ryphlex 04-18-2008 05:51 PM
It'll fit.
I run 19 x 8.5 +30.
