Need some help on tires. 19x8.5 offset 35
I have a set of stern ST-2 19x8.5 offset 35, and I'm lowered on TRD springs.
The tires that are on the wheel right now are 225/35/19 front, and 235/35/19 rear. I was wondering if i will have any problem with the 235 in the rear? will i rub? https://www.scionlife.com/forums/scion-tc-1g-wheel-tire-1646/what-fits-tc-list-%7C-updated-4-2-08-a-45552/ On this thread ^^^^ it show that i will have a problem even with 225. But on this bottom thread it say that i can have 245. https://www.scionlife.com/forums/sho...d.php?t=142934 please give me some advice or any help would be great. Thanks Should I change the tires? or keep the F:225/R:235 1. Front 225/35/19 Back 225/35/19 2. Front 215/35/19 Back 225/35/19 |
anybody...??? bump
Any reason why you don't have the same size all around? I'd say just go for 225's on all 4 corners.
I got the rims used and it came with 235. The tires is almost new, so i dont want to waste it and change it. But if i have too then i will.
on trd's you shouldn't have any problems. Just keep what they have on them.
I think you'd be safer on 225's. +35 on a 8.5'' wheel with 235's might rub.
maybe with people in the back.
thanks u guys. i will try to see if the 235 going to rub or not. If it does. Do u think it is better if it change it to 225 to have a full 225 all around or change it to 215 and put it in the front and 225 in the rear?
I have 215/35 on 8.5, but only cause I wanted a bit of a stretch so I could lower my car more. Your on trd's so if you get smaller tires it will make the wheel gap even more noticeable..
Thanks alot! i guess if it does rubs, i will change it to 225.
yeah or just roll your fenders.
Yeah, maybe rolling the fender will be cheaper then change to two new tires. Since the current tires have like 90% tread left.
yup..there you go cause 19" tires do not come cheap.. You can do it yourself with a heat gun, bat and a lot of patience for free..thats what I did. And they came out flawless, it was my first time.
I have 225/35's and I don't rub...my tires are slightly stretched though.
My wheels are 19x8.5 Axis Shines on all four corners. TRD Springs. Keep what you have, 225/35/19 should work when you need new tires. The 235 will be fine, you'll have plenty of room. 245 would push it! |
i also have axis shines with 19x8.5 35 in the front and 19x9.5 40 in the rear with 255/35/19 in the rear and 235/35/19 in the front. i cut my rears. and left my front alone. i'm lowered on eibach prokit springs
some meaty tires...got any pics?
I'll try to get some picture this weekend. Thanks again!
2 Attachment(s)
(Post 3492161)
http://i305.photobucket.com/albums/n...PICT0009-1.jpg Attachment 94891 |
Nice lip! How you like your 19's do you think their to big? And I think it would look better if you lowered it and stretch tires...thats just me :P
i like them and i wanted to go lower but am not really into the whole stretch/slammed look it does look nice though from time to time. im going back to 17s though.
