New Wheel Fitment Thread
Old Sep 30, 2008 | 10:33 PM
  #41
nebster's Avatar
lol yes
Old Oct 1, 2008 | 04:20 PM
  #42
misformartin's Avatar
well i will trim the fenders out and and minor pull...
Old Oct 8, 2008 | 09:45 AM
  #43
TylerC08's Avatar
Switching from Htechs to Stechs with my 18x8 et37, 225/40... I assume I will be rubbing front and back...or just the rear?
Old Oct 8, 2008 | 11:07 AM
  #44
nebster's Avatar
probably just the front, and even then you may not.
Old Oct 9, 2008 | 07:29 AM
  #45
STNC's Avatar
S-Techs? H-Techs not low enough, we have to hop from the letter H to the letter S....That's a big difference
Old Oct 13, 2008 | 10:48 PM
  #46
menace549's Avatar
I'm on TRD looking at 18x7.5 +42 front, no issues there, but i'm concerned about the 18x9.5 +35 rear on a 225 tire. Should I worry about rubbing?
Old Oct 14, 2008 | 11:53 AM
  #47
nebster's Avatar
yes you will rub with that wheel / tire combo, you will have to modify your fenders by rolling / cutting to minimize the rubbing
Old Oct 14, 2008 | 10:32 PM
  #48
menace549's Avatar
Thanks for the help.
Old Oct 15, 2008 | 02:58 PM
  #49
David616's Avatar
I am looking to get 18x9.5 +25 all around. Will be running 245/35 tires. Would I be able to do that setup?
Old Oct 15, 2008 | 03:02 PM
  #50
nebster's Avatar
not at all. you wont fit front and your rears will be rubbing horribly.
you're not getting enough stretch with the 245 on the 9.5 in order to make them fit without modifying the fender
Old Oct 16, 2008 | 06:18 PM
  #51
Akrylic09's Avatar
hahahah i never thought id see the day in which id need good ol nebsters help but here i am askin the pro....
im going to come up on some wheels tomorrow ....the only problem is that there 18x9 et+35 all around. i know im going to need to roll and pull the fenders but how much exactly? am i going to need a mild roll and pull or is it going to be bad enough that i also need to cut? im in a bind right now and i need to get back to this guy by today....
thanks
Old Oct 16, 2008 | 09:24 PM
  #52
nebster's Avatar
i had to cut with a 18x8.5 et+30 so you'll have to cut with a 9et+35, you'll be out one more mm than me , what tire are you running?
Old Oct 16, 2008 | 09:39 PM
  #53
Akrylic09's Avatar
im not sure what im going to run just yet.....i dont want it to stretched like a rubber band tho....
Old Oct 16, 2008 | 09:49 PM
  #54
nebster's Avatar
the bigger your tire will be the more you'll have to cut
Old Oct 16, 2008 | 10:08 PM
  #55
Akrylic09's Avatar
hahahah i think im confused.....when you say cut do you mean cut the actual fender like that one guy in hawaii did or just cut the inside of the wheel well. i just want to make sure were taking about the same kind of cutting.
Old Oct 16, 2008 | 10:16 PM
  #56
nebster's Avatar
cut the inside of the wheel well, i wouldn't cut the outside of the fender
Old Oct 16, 2008 | 10:29 PM
  #57
Akrylic09's Avatar
yea thats what i was thinking too but i just wanted to make sure since its a wide wheel i didnt know if i actually had to cut like that white "vip" tc in hawaii. i got it now tho. but i should be fine running a 9in wheel in the back right...with that offset?
Old Oct 17, 2008 | 12:42 AM
  #58
nebster's Avatar
yeah you'll be fine for the rear
Old Oct 18, 2008 | 05:05 AM
  #59
Skeletor's Avatar
For the wheel guru's ;18x8 35 offset, or 48 offset ?, how would that fit with 245 tire? im on htechs but plan on going lower.
Old Oct 19, 2008 | 01:47 PM
  #60
tCrollin08's Avatar
I'm looking at these wheels
http://www.1010tires.com/wheel.asp?w...wheelbrand=ADR
My bolt pattern is 5x100, wondering if I will be able to to fit the 18x8.5 with 112 bolt pattern. Is there some type of adapter I will need for that or is my only option the 7.5" wheel??
