Stance rookie looking for help!
Hey guys I've had my 06 scion for about a year now and after spending countless hours on the aggressive fitment thread I've decided it's my turn to do the same but I'm in need of some serious help because I'm a noob in the car game.
As of right now my car is completely stock but I'm very very interested in running a set up I found online that a guy is running.
His set up is:
xxr 531s 17x10 with a 215/40
raceland coilovers
rolled fenders
Will I need to do anything else to run this set up?
Any clearance issues? (I know I'm going to rub)
Will I need camber bolts?
I have cash in hand and I'm ready to make some purchases.
PLEASE HELP!
His set up is:
raceland coilovers
rolled fenders
PLEASE HELP!
You will need front camber with those xxr's regardless of offset (because you didn't mention it) The rears, if rolled, might settle in just barely if the offset it right, otherwise, you will need to camber the back as well. Other than that you know what you need to do and how to get it, so let us know how it goes and your progress with the whole thing or if you have more questions.
Ah yeah, sorry forgot to mention that. I was looking at getting them from nlmotoring.com
This is what they have:
Specifications
Wheel Size
17x10
Color
Gold
Bolt Pattern
5-100/5-114.3
Offset
+20
Backspacing
6.29
Lip Depth
3.0"
Centerbore
73.1
TPMS Compatible
Yes
Approx. Weight
20.8
JWL/VIA Certified
Yes
Required Lug Nuts
Tuner Style
Specifications
Wheel Size
17x10
Color
Gold
Bolt Pattern
5-100/5-114.3
Offset
+20
Backspacing
6.29
Lip Depth
3.0"
Centerbore
73.1
TPMS Compatible
Yes
Approx. Weight
20.8
JWL/VIA Certified
Yes
Required Lug Nuts
Tuner Style
Thanks man, I'm super pumped. Ordered my coils and wheels last night. Going to get tires and look into what I need as far as camber bolts and any other miscellaneous stuff tonight. Once I get everything lined up I'll start a build thread.
Needless to say my bank account is a bit smaller compared to when I woke up yesterday morning hahaha. Overall it's a pretty cheap cosmetic build unless I start popping the hood for new ideas.
new wheels ..need help
I have an 07 scion tc and I was looking to get Esm wheels.
Size
17x10
Offset
20
Center bore
57.1
Bolt pattern
5x100
My car it already low I just want to make sure I won't have any problems. Is there anything else I need to know before I get them?
Size
17x10
Offset
20
Center bore
57.1
Bolt pattern
5x100
I went with federal tires for mine and went with 215/40 I'd go with a 215/35 if I were you especially if you want to dump it. I used to the stock camber in the rear and camber bolts in the front but I personally wish I had more camber in the rear.
Hope this helps!
domincnTC
08-04-2015 01:47 PM
