Are there different Lugnuts for Stock wheels??
I thought I had the correct lugnuts I purchased the McGard Blk Spline drive ones...when I went to switch out the wheels the Guy told me that my wheels could have fallen off!!..Haha...That would of Suked!!!...
I need the Mag Short shanked type of Lug Nut...But are there any aftermarket ones in different colors or styles that fit the Stock wheels?????? Thanks again!! |
https://www.tirerack.com/images/wheels/tech/lug_nut.jpg
While many aftermarket alloy wheels are designed to use your car's original lug nuts or bolts, others require new hardware. It may be something as critical as differences in the wheel's lug seat design as shown below, or something as simple as shorter lug heads to allow the wheel's center caps to fit. If your new wheels require new hardware, your invoice will list the appropriate quantity identified by our part description, beginning with an "N" for lug nuts or a "B" for lug bolts followed by the size, pitch, seat design, length and the appropriate lug wrench socket size. NOTE: Keep a set of your vehicle’s Original Equipment lug nuts or bolts in the trunk just in case you ever need to use your factory spare tire, which must always be installed with the Original Equipment lug hardware. ***stock is flat type |
I think he has the stock wheels bu he panted them, so he's looking for some black ones.
Re: Are there different Lugnuts for Stock wheels??
Look at your stock Lug Nuts..theres a Washer attached to the nut..I need that type of lug nuts for the OEM wheels...not just a regular kinda lug nut...
Have you tryed Super Autobacs in Stanton (right next to Knotts)?? Nice little drive I know, but they have tons 'o' stuff.
Nobody wants to go w/ me:( :( Looks pretty Pimp-ish....Super AutoBacs!! |
