Will I rub??
I am dropped on eibach sportline springs running rotiform 17 x 8 et 30 plus 25mm spacer, can I run a 215/45/17 tire or will I rub?
I had 205/40/17's and even with 1000lb's in car no rubbing. But since I had a tire blow out I have my stock tires 215/45/17 and I am planning on running those until I save up for new tires. Thanks! Also my fenders are slightly rolled, which means the inside fender lip has been removed |
If your fenders are already slightly rolled, then you I doubt you will be rubbing. Especially since you are not dropped too low, I wouldn't worry about it. 215 is still a pretty small tire.
Originally Posted by 2006steezypurps
(Post 4127981)
will I rub?
X2 ^ Especially with how wide your wheel is you'll be fine.
