2014 10 Series light up Badges mod?
I have a new tC 10 Series and am looking to make the front and rear badges stay on when the car is running.
Anyone have any ideas on how to?
___
___
No don't tap into a constant power. Otherwise the power will be on all the time. If you want it to be on during the night time then tap the badge into your parking light (+ blue wire).
Send to PrinterClose Window
2013 Scion tC Parking Lights (+) There are currently no notes for this item.©2012 Directed Electronics. All Rights Reserved.
Click photo to view a larger version
(*** not all photos have a larger version)
But as already mentioned, what resistor and where?
So what would a person do if they wanted something to have power to it all the time when the car is on? Hmm... probably tap into a wire that has power ALL THE TIME.
Really? SO go ahead and do what Criminal says so that your lights will be on even when the car is off and parked.
Simply wire it to an accessory or ignition.
____
____
sorry but wasn't specified. Can't expect someone to know exactly what you're thinking. But 12V+ with key on can either be Accessory or Ignition. Constant is constant whether the car is on or not. Sorry, I was reading into it as an installer. But that's my point. Just like you said don't be vague. I'm on this forum to learn and to teach when I can. There are times that I have been corrected due to misinterpretations and I myself have corrected people. It's a part of being human. Let's try to keep this friendly and informative without being judgmental.
To Torranosaurus use this as a guide. Always test wires before making connections. Ignition gray wire white 8 pin plug pin #6 at ignition switch, can also use Accessory black wire pin #3 at same location. Good Luck
