Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
Help with Reverse Light Kit from Obnoxious Performance
Old 06-23-2011, 07:14 PM
scionchicop's Avatar
Default Help with Reverse Light Kit from Obnoxious Performance
I have everything hooked up and watched the video several times for help with install. Light still does not light up. Just to confirm, does the t-tap go on black cable or black and white cable. I put it on black cable which is what vid says but that didn't work. Help please!
scionchicop is offline
Old 06-23-2011, 07:20 PM
tCTRICE10's Avatar
Any pic ?
tCTRICE10 is offline
Old 06-23-2011, 08:16 PM
highvoltage1's Avatar
Didnt know someone came out with a kit for this? Not a bad idea though!
You contact them for help?
highvoltage1 is offline
Old 06-23-2011, 09:06 PM
2tCornot2tC's Avatar
When you look at the connector, they are the two corner wires. If the wires are not in the corner of the connector, you got the wrong wires. One corner has a red wire, the other a black/white one as shown below...
2tCornot2tC is offline
Old 06-23-2011, 09:39 PM
heydan's Avatar
Thumbs up
http://www.obnoxiousperformance.com/..._p/obx-2rl.htm
heydan is offline
Old 06-23-2011, 09:40 PM
Papa_Bear's Avatar
Did you cut the wire to actually have a good connection? The blue connector does not cut the wire for you. You need to get to bate wire before the kit can actually receive voltage. Had a few people forget to do that
Papa_Bear is offline
Old 06-29-2011, 02:00 AM
Looking at 2cornot2c wires, my setup does not go in the wires that you tapped into. Papa bear, is it the white and black cable or the black cable only? I stripped the black cable. Could the bulb be out?
Old 06-29-2011, 03:36 AM
goose_119's Avatar
it is the black wire. white/black is ground.
goose_119 is offline
Old 06-29-2011, 12:10 PM
Yes...the black/white wire is the ground...so, it does not have to go all the way accross the car. You can just ground it there on the right side, by the tail light itself.
SkillFreeJake
07-27-2015 12:34 AM
hampton1100
05-28-2015 07:32 AM
randomsuper
01-25-2015 01:09 AM
scsteven
01-25-2015 01:06 AM
amart
Scion xD Aero & Exterior
12-23-2014 12:06 PM
Quick Reply: Help with Reverse Light Kit from Obnoxious Performance
