Help with Reverse Light Kit from Obnoxious Performance
I have everything hooked up and watched the video several times for help with install. Light still does not light up. Just to confirm, does the t-tap go on black cable or black and white cable. I put it on black cable which is what vid says but that didn't work. Help please!
Any pic ?
Didnt know someone came out with a kit for this? Not a bad idea though!
You contact them for help? |
When you look at the connector, they are the two corner wires. If the wires are not in the corner of the connector, you got the wrong wires. One corner has a red wire, the other a black/white one as shown below...
https://www.scionlife.com/forums/pic...pictureid=9871 |
Originally Posted by highvoltage1
(Post 3863827)
Did you cut the wire to actually have a good connection? The blue connector does not cut the wire for you. You need to get to bate wire before the kit can actually receive voltage. Had a few people forget to do that
Looking at 2cornot2c wires, my setup does not go in the wires that you tapped into. Papa bear, is it the white and black cable or the black cable only? I stripped the black cable. Could the bulb be out?
it is the black wire. white/black is ground.
Yes...the black/white wire is the ground...so, it does not have to go all the way accross the car. You can just ground it there on the right side, by the tail light itself.
