High Intensity Yellow/Amber FOG bulbs?
Currently running a pair of regular yellow incandescent bulbs in my stock FOG light housings.
I'm looking for a brighter bulb in either amber/yellow using LEDS and I don't want to have to retrofit for HIDs etc. Anyone have any suggestions for brighter LED H11 options? |
No "retrofitting" is required for the using HIDs in fogs. Just get a H11 HID kit. H11 LED bulbs are expensive and cost the same (and often more) than HIDs.
Recommend just going with HIDs. But if you MUST go LED, the VLEDs V3 Triton bulb is a beast. |
Originally Posted by biglilsteve
(Post 4174935)
Originally Posted by pro710
(Post 4174937)
Steve, doesn't the HID Fogs require more power and ballasts that need to be run to battery etc?
Prior to my retrofit though, I ran a 55w DDM HID kit in my stock headlights and a 35w DDM HID kit in my stock fog lights all WITHOUT a relay. This setup ran perfectly fine for me for over 3 years until I did my retrofit. The only reason I began using the relay is because Morimoto kits come with them included so I figured, why not. |
(Post 4174938)
That's a good question. Some folks like to run a relay that grabs power directly from the car battery. I began doing that for my headlights after I did my Lexus RX350 projector retrofit.
Prior to my retrofit though, I ran a 55w DDM HID kit in my stock headlights and a 35w DDM HID kit in my stock fog lights all WITHOUT a relay. This setup ran perfectly fine for me for over 3 years until I did my retrofit. The only reason I began using the relay is because Morimoto kits come with them included so I figured, why not. Steve, can you provide a link to one of these HID plug-n-play options or PM me Please? |
Yup, you will absolutely be able to get away with simply plugging the ballast into your factory wiring for the fogs.
Pretty much all aftermarket HID kits are plug and plan as long as you get an H11 kit. I personally used DDM Tuning back in the day but a lot of folks complain about their customer service these days. DDM Tuning: HID and LED Lighting That's today's equivalent of what I used a few years ago. Just make sure you chose 35w, H11 bulbs, and 3000k bulb color for yellow. |
(Post 4174944)
(Post 4174959)
Biglil, You da Man! Thanks for the link. I think Scionlife or others have coupon code for DDM Tuning right? You happen to know any codes I can use? Thanks in advance bud!
