How to install OEM fogs on tC 2015?
Hi everyone can you help me. I need to install fog lights on my tC 2015.
Is there a wire ready on the front bumper or should I connect it to a different source and where should I put the switch inside the car?
Thank you!
Your help is greatly appreciated!
____
Thank you!
____
The OEM Fog Lights Install for tC2=2011-2013 Are Different than for tC2.5=2014-2016.
Here you go for tC2=2011-2013:
http://toyotaparts.sparkstoyota.com/...-79417inst.pdf
tC2.5 Install Instructions are 16 pages long. tC2 Install Instructions are 9 pages long.
MR_LUV
I find it fairly easy to just pull down the splash shield and work in the fogs from there, but the bumper is not hard to remove. With how easy they are to access and only needing to remove 2-3 screws per side though, you could have them swapped in less time than it would take to remove the bumper. I added fogs to my car and did the whole install without removing the bumper, I don't see a reason to for this.
is the splash guard the wheel well? i installed the fog lights professionally, so they took off the bumper im guessing but i want to change the light bulbs because they are flickering and i wanna do it myself save me some money.
Yes its that part, it wraps all around and under the bumper. Start buy removing the 2 10mm's holding it on the bottom of the bumper and see if you have enough leverage to access all the stuff. When you actually look at it it's very simple.
