Spec-D Headlight Bulb Replacement Question
So the new headlights from Spec-D come with an H7 bulb and it seems like it works as both a high and low beam. I want to replace this with an HID kit or at least just change the color and output since I'm used to driving with HID's, but I do not know which kind of kit I would need. Any kind of info would be useful. I've emailed Spec-D and theretrofitsource about it but they haven't given me a clear answer on what I should do or need.
Originally Posted by RawrSauce
(Post 4169316)
OEM Headlight Bulb Sizes: 2005 - 2007 Scion tC Low Beam: 9006 High Beam: 9005 2008 - 2010 Scion tC Low Beam: H11 High Beam: 9005 2011+ Scion tC2 Low Beam: H11 High Beam: 9005 2004 - 2007 Scion xA Low Beam: H4 / 9003 High Beam: H4 / 9003 2004 - 2007 Scion xB Low Beam: H4 / 9003 High Beam: H4 / 9003 2008 - 2012 Scion xB2 Low Beam: H11 High Beam: 9005 2008 - 2012 Scion xD Low Beam: H4 / 9003 High Beam: H4 / 9003 OEM Fog Light Bulb Sizes 2005-2010 Scion tC H11 2011+ Scion tC2 H11 2004 - 2006 Scion xB 9006 Source - http://www.fastscions.com/onex-hid-c...on-models.aspx |
So side note about Spec D headlights they are not HID ready. What that means is you may have to do some cutting where the bulb goes into to make them work. I wanted to get Spec D for my car but I called them and they said HIDs will not be a direct fit into them. They also said that HIDs might destroy them after awhile because they are not built to withstand the heat that HIDs put off. There are companies out there that have HID ready headlights.
Originally Posted by Skatermillar
(Post 4169340)
i think the hedlights look awesome without the headlights on lol i just keep my fogs on at there sametime as the boomerang lights
