1 second rattle on cold start
Anybody else have this 1 second rattle on cold startup. Sounds like cam waiting for oil. Like when you first start a motor after oil change and the filter has no oil in it yet. Seams to be a pretty widespread problem on the 2arfe motor. I've been browsing around and a lot of people say it's some vvt-i lock pin problem while others say it's just the hydraulics lifters before they build up pressure. If everyone else has the same problem I'm not going to bother going to the dealer. I suppose if it's the lifters before they build pressure it's not really a problem, but just the nature of hydraulic lifters. Thanks guys !
Ya I think i should be able to get the dealer to fix it. I found tsb for camry and rav4. I finally just found the exact same tsb for the scion tc published in 2013. Something along the lines of replacing cam gears.
Good to know if the dealership screws me. Don't see how they could reject me when i have the tsb number tho. How many miles you have russiankid. Or the rav4 for that matter. A high mileage motor with the issue would settle me down a bit. Pretty wound up. Been doing it since i picked it up brand new. Now has 2600km on it. In 3 weeks lol. No issues other than that annoying cold start rattle. Sounds so harsh on the motor. Prob cuz it sounds like cam to me even tho its not.
All i got is the tsb number and what it is "S-SB -0010-13 Brief engine knock/rattle noise at cold startup". The website I found it on wants money to see the details. But if you google camry startup noise tsb it's the same thing. Replaces cam gears and something to do with the vvt-i system as there is a pin that's supposed to lock into the cam gear at startup to make for smoother/quicker starts or something like that. It doesn't lock in and rattles until oil pressure gets to it. Not word for word but that's the just of it. Here is a clip of the sound from someone else. http://m.youtube.com/watch?v=Kn4TFKggiKI
I dunno that's what the tsb says. It's because at shutdown the vvt-i locks a pin into the cam gear to change timing for easier startup or something. So pin doesn't go in properly then rattles at startup until oil gets to it. If you've never had issues with high mileage I'm not worried about it I guess. Here is another video of it in a rav4.http://m.youtube.com/watch?v=ZK3jEwMZoRc
Same noise I have but I don't think mine is that loud, not to mention I don't really hear it anymore with the exhaust. I don't think this noise will cause any damage so having another nut job at a dealer tear into the valve train is unneeded. I've had enough bad experiences with dealers and my transmission, don't want to deal with the engine now.
Ya mine doesn't seam to be that loud either. More like the first video. The 2nd rav4 video is much louder. I've seen some people saying it could just be hydraulic lifters before they build oil pressure or something. O well if it gets worse I'll just go rage on them until they fix it. Otherwise screw it. I've heard toyota uses synthetic from the factory with a break in additive, may be the cause of this too. Your always suppose to break in a motor for 5-10,000km on conventional oil then move to synthetic. I may have been misinformed about this tho.
This topic has been beaten to death.
Noise is from your intake cam gear(vvt-i gear). Common problem on the 2AR-FE engine.
See this thread: https://www.scionlife.com/forums/sho...d.php?t=224756
The additive is most likely a safety measure because the general public doesn't understand that things need to wear into each other before you go beating around on the car. If you have half a brain, you'll understand this simple principle and everything will be fine. A lot of engines that are rebuilt/built don't use any special oils for break in.
mw1957
Mar 16, 2015 06:00 PM
CPL_Radar
Mar 5, 2015 05:42 AM
cid_mcdp
Jan 5, 2015 02:45 PM
minter66
Dec 15, 2014 01:45 PM
