2013 Scion tC Wont Start after wreck..
I bought a Scion wrecked in the front. After getting it home turn the key and dash comes on. No power anywhere else.
No door locks, windows won't work, no radio. Car don't click when turned to start. Only power is the dash light. Any help would be appreciated. *Moved to Correct Forum by Administrator Sticky Where to Post Your Question ______________________________ |
Originally Posted by Smokeuu
(Post 4293952)
Car dont click when turned to start.
Pop the hood and eyeball the starter. Check for loose connection(s) and or broken actuator. Test the battery to make sure it's charged. |
Originally Posted by 62Fender
(Post 4293994)
Have you removed the damaged parts? Not sure you'll find anything that prevents starting but may be worth a shot.
Might try a DTC scan (assuming the socket is getting power with the key is in the on position.) |
(Post 4293996)
Sounds like you'll need to meter each component from the battery to the ECU. Might also inspect the front end ground point(s) to make sure they're intact.
