Cylinder 1 Misfire
Cylinder 1 Misfire
Hi all,
My 2011 Scion tC has been giving a misfire on Cylinder 1 both on idle and when driving. Things we've tired so far:
Change fuel injector
Change all spark plugs
Swap out coil pack with 2013 model pack
Check MAF
Check O2 Sensor
compression test.
However the problem persists. Thinking of getting a new set of coil packs as the set that was swapped from the 2013 model may have been weak.
Any suggestions?
Thanks
______________________________
Check MAF
Check O2 Sensor
compression test.
Any suggestions?
Thanks
Last edited by MR_LUV; 08-28-2018 at 01:03 AM. Reason: Moved to Correct Forum by Administrator
jhalski
Scion xD Drivetrain & Power
10
01-10-2023 02:26 PM
Timmah
11-06-2016 12:09 AM
davidward
27
02-02-2015 02:07 PM
