tC2 Flywheel options
Looking to put in a lightweight flywheel-either steel or aluminum but Ill probably end up going with the heaviest of the light weight options. So far I have found three companies that make flywheels. I want to hear what people are using and what weight as well. Ive had an 8 pound flywheel (also had all aluminum pulleys as well)l on my old 4ag so I understand the downsides to having too light of a flywheel for a street application.
◄◄Click Here to Add your Vehicle to Garage Stock 17.7 pounds (steel) Competition Clutch 11.9 pounds (steel) (267$) Clutch Master 14 pounds (steel) 11 pounds (aluminum) ( each 445$) ACT 9.8 pounds (aluminum) (277$) Thanks What does Garage is empty, Add now mean? |
hopefully their info i right. I wanted to know the weight of the stock flywheel. Going to strip weight out of my tc. I'm going with ACT's flywheel being that its the lightest around and cheapest.
For the record any 2azfe flywheel and arp bolt kit works perfect with the 2arfe and 2arfe clutch
◄◄Click Here to Add your Vehicle to Garage What does Garage is empty, Add now mean? |
what benefit is getting rid of an solid performing flywheel for...?
