Transmission noise? Clutch? WTF
#101
Not 100 % if we have the same problem but I was talking to a guy I use to work with at toyota and there seems to be a problem with the 2nd generation tc input shaft bearing. There have been a lot of people bringing in their TCs for transmission noise. Most mechanics diagnosed it as a throw out bearing but fail to fix the problem. Unfortunately for me the only one person in my area has actauly fixed the problem and it's the input shaft bearing which is pretty much what allows the main gear shaft to turn and you have to open the transmission to fix it. It's actually only a 30 dollar part but not something you want to mess with if you are not experienced with transmissions. From what I heard toyota is thinking about doing a recall on that part but unfortunately this isn't something you want to wait to fix. If the bearing ceases up completely it will bore a hole in your transmission and then well... you'll have to get a new one. Anyway hope that your problem isn't a server
I'm hoping Toyota further acknowledges there is an issue and finds a better solution then to repair with the same part only to have it fail as well.
#106
anyways, RussianKid pulled through for me. He got me a copy of the tsb. anyone else that may need it, here is the info:
TSB: S-SB-0008-13
DATE: 2/14/2013
Growling Noise with Cutch Pedal Released
#108
Find another one and look at that.. Or just buy a new one, since the interest rates are lower on new anyway..
#110
when i test drove the XB1 i chirped 2nd every time i shifted it to annoy the dealer.. It was fun.. hahahaa..
#113
Fisqual
09-22-2015 05:51 AM
2011, clutch, gear, gen, manual, noise, noisy, ransmision, scion, scionxbloudsquealfromthrowoutbearing, tc, tranny, transmission, whine, xb
