//Dezod// AEM EMS for TC2 is now ready
Did some recent testing on a 6 speed TC2 with our kit and 3" exhaust and where impressed to say the least....Made 320whp at 10.5 PSI instead of 11.5 PSI on the FIC. Drive-ability was FAR improved as well.
With our AEM EMS, you will have full control over fuel, ignition and VVTi. This is a must for anyone looking to make serious, reliable, hardcore power.
System includes the following components
Modified V2 AEM EMS box
Plug-and-play harness
Start up AEM TUNER V24 CAL
Intake air temp sensor
Choice of 3 or 5 BAR MAP sensor
Only snag with this setup is that you must wire the coolant fan to the EMS or to a switched 12V source because this ECU has no fan control pin on it.
Pricing is here:
http://www.dezod.com/pd_dezod_motors...m-scion_tc.cfm
Pricing is here:
Not yet on the turbo system. You would need to purchase the tuner system and then an injector upgrade to run it with it.
so just to confirm that this is not to be matched with the turbo? is there a plan to make this work with the turbo system?
If you wanted this combo of our kit and the EMS, you would have to purchase the EMS here:
the tuner turbo kit here:
http://www.dezod.com/pd-dezod-scion.cfm
and some injectors of choice:
http://www.dezod.com/pd-deatsch.cfm
or
http://www.dezod.com/pd-injector-dyn...jectors-tc.cfm
Total cost of said kit with EMS would run around $5928.00. Not bad in the grand scheme of things for what you get.
We have decided not to make the AEM EMS available in a kit for a few reasons. However, it's not impossible to have it and we can provide a base calibration based off of our kit with the EMS as well.
or
or
So would you recommend using the tuner program? im looking at getting the kit soon. i dont want to run more than 8lbs of boost.
The tuner kit doesn't include fuel and engine management (So adding the EMS and injectors makes sense)
The complete kit includes both! (AEM FIC, PNP harness and injectors)
NGK Iridium and it will depend on the boost you run. We run most TC2 with 10-11 PSI on the stock plug. Anything more, I'd recommend 1 step colder.
