Help with electronic Boost controller on Dezod kit
To start off, Im Chris, I have a 2014 TC and i am in the middle of installing a DEzod turbo kit.
Currently, I am trying to hook up the vacuum lines and it seems like the distribution block is missing a fitting so i can "T" it off the brake boster. so i guess i have to go buy that.
My big question, I have a greddy Profec boost controller and i am trying to hook up the solenoid. I know one goes to the wastegate and the other calls for a source on the compressor outlet. But the Garrett Turbo does not have any source. so... What are my options? do I have to take all of this back apart so i can drill and tap a fitting? or can i get the source from somewhere else?
also, about the main vacuum source that im getting off the brake booster, am i missing something?
Read that manual and see if it can take a boost and vac hookup. If it can, then use the vac manifold. If not, then you must remove the compressor housing, tap for a fitting and then reinstall.
my06tc
06-25-2015 12:18 AM
spawnconnery
12-18-2014 08:38 PM
