PTUNING: 2011 Scion tC Turbo Kit (Available to ship)
#501
Andrew, thanks for your answers and help!
In Russia, as well as in Europe uses a system of calculation of the octane number - RON. In the USA it is AKI or PON. That is, Russian 98 = USA 93. At week I will go to the tuner and will tell you about my results.
Is correctly the fan is located? It's on the the driver's side
Drew. R
#502
#503
I will be able to further assist you there.
Drew.R
#505
Another PTUNING turbo tc2 for the books. Thank you for looking.
PTUNING Spec-SS turbo kit for the 2011 Scion tC2 287 WHP @ 7psi
Mods:
-PTUNING Spec-SS turbo kit (stock motor)
-DW 550CC injectors (stock fuel pump)
-Stock clutch.
-Stock S-pipe and mid-pipe.
-HKS axle back.
Mods:
-Stock clutch.
-HKS axle back.
#508
Depending on how you treat the clutch the stock setup will hold out for a decent amount of time. I currently have 3 customers on stock clutches running 9-10psi daily.
Our recommended upgrade for this car has been the ACT-HDSS version with a full face disk.
Drew. R
Drew. R
#509
Please send all technical questions to andrew@ptuning.com
Drew.R
Drew.R
I returned from a certified tuner AEM.
Capacity of the car turned out 370 hp
Specs:
1. ACT Heavy Duty Clutch Kit
2. ACT Xact PROLITE Lightweight Chrome-moly Flywheel
3. OS Giken OS Super Lock LSD
4. Greddy RS Exhaust
Petrol 93
At 5,500+ rpm turbine blows 1 bar = 14 psi
Is it not so much? Does not damage the engine?
What can you tell me about the schedule?
Torque is measured in newton-meters (nm)
#511
#512
Have you guys turbo any automatic cars? if so how did they run on dyno? and if turboed what would you suggest running the turbo's psi at on a daily driver? Any issues or problems come up with daily driven ones?
#513
On a Manual tC we recommend 8-10psi and 12psi with a fuel pump. Both these numbers can used on a daily driver. Hp numbers will range between 290-320 depending on fuel and psi used.
Drew. R
#514
Currently we have not turbo'd any automatic Tc2 cars. So I can not supply you with dyno numbers.
Drew. R
Drew. R
