Scion tC 2G Forced Induction Turbo and supercharger applications
Vimont 2011 Scion tC Turbo
Old 07-06-2011, 05:00 AM
Synoptic's Avatar
For now, Canada, starting with Quebec, but you will be able to buy it from us "the makers" too.
It includes :
Manifold, Turbo, intercooler, 3 inch complete exhaust, with Cat, resonator, muffler, all pipes, engine management, and all other parts necessary to install. It is an ALL INCLUDED kit.
Synoptic is offline
Old 07-06-2011, 06:16 PM
crazydrummer7's Avatar
That's awesome, thanks for the info. I am definitely looking into this. Have you looked at the descendant racing turbo for this car? What are your thoughts on it?
crazydrummer7 is offline
Old 07-06-2011, 06:25 PM
Synoptic's Avatar
We h ave looked at Descendant kit, ans we found it to be very high quality. In fact, our kit contains some parts made by Descendant, but we did not like the powerband it gives. More HP at high RPM than ours, but less power before. Also, if you look carefully on their youtube video, you see that the boost level starts from 2PSI and finishes around 8-10PSI at 6000rpm.
Our boost curve is 8PSI from 2800 RPM up to redline (6300). Make a more predictable car, and a bit more low-end torque. Our kit has less parts to install too.
I personally think they chose a too big turbo for the car, but on the other hand, they give you all necessary components to make a LOT more power if you replace the OEM clutch and build the motor.
Our Stage 1 kit does not gives much more room for power (well, it does, but not as much as theirs). We aim at daily driven cars, driven by a wide range of people. If Toyota had made this car turbo from the factory, it would resemble our kit more than Descendant I think.
Synoptic is offline
Old 07-06-2011, 06:43 PM
Ah, thanks for the thoughtful response. The only reason I was really concerned was that the stock motor produces a compression ration of 10.4:1 I believe. Isn't it kind of dangerous to turbo with that high of compression?
I feel safer, now that your kit is almost ready to hit production. I know the descendant kit produces more power, however like you said, I fall into the daily driver category. Therefor, I would most likely go with this kit.
Old 07-06-2011, 06:45 PM
Synoptic's Avatar
10.4:1 is not an issue at all. Honda's motor with more than 11:1 ratio are boosted on a regular basis with no issue. It all depends how bad you're boosting the engine. You need to respect how the motor has been built for a safe setup.
Synoptic is offline
Old 07-06-2011, 09:24 PM
Synoptic's Avatar
The kit is soo friendly, even my Grand'ma drives the car !
Synoptic is offline
Old 07-07-2011, 12:40 AM
scionchicop's Avatar
How soon will this be avail for purchase and pricerange???
scionchicop is offline
Old 07-07-2011, 12:51 AM
Synoptic's Avatar
price range 4000 - 5000
When : Within 2 weeks normally. We're waiting on tubing to do some MAF relocation to fix a 2500rpm hesitation due to turbulence.
Synoptic is offline
Old 07-07-2011, 03:27 AM
will the stage 1 be safe with the stock clutch? or would a new clutch be recommended?
Old 07-07-2011, 05:03 AM
Blackedout011TC's Avatar
Depends on your right foot. I like what you guys are shooting for.. A turbo kit with more power in the lower revs will be more reliable and fun to drive. I don't want my D.D. to run like a 125CC 2 stroke dirt bike. I could care less if I am making 500h.p at 5500rpms if I am only getting 150hp at 2800rpms. I'm not racing nor am I trying to impress anyone on here. I just want more power where it is needed. I will be waiting!
Blackedout011TC is offline
Old 07-07-2011, 12:36 PM
Synoptic's Avatar
We've designed the kit so the OEM clutch can handle it.
Synoptic is offline
Old 07-08-2011, 03:32 PM
neoshadow's Avatar
so far the stock clutch is going great, we test drived the car on a track and every is good.
neoshadow is offline
Old 07-08-2011, 09:03 PM
GUNNIST14's Avatar
The 2AR has great power potential at 12psi making 350 this motor is a beast.
GUNNIST14 is offline
Old 07-13-2011, 09:46 AM
Mister_D's Avatar
Make sure to follow the build and the stage 2 our Facebook page
JDM Transplant
https://www.facebook.com/#!/pages/JD...78324585558994
Mister_D is offline
Old 12-31-2017, 04:09 AM
Administrator
Administrator
MR_LUV's Avatar
Thumbs up
MR_LUV is offline
cessblood
09-15-2015 06:50 AM
2CTC
09-12-2015 11:33 AM
BrokenTC2
01-27-2015 03:32 AM
spawnconnery
12-18-2014 08:38 PM
ScionLife Editor
11-25-2014 03:00 PM
Quick Reply: Vimont 2011 Scion tC Turbo
