Scion tC 2G ICE & Interior In-car entertainment and electronics...
2nd Gen tC Wiring Diagram
Old 07-14-2011, 12:22 AM
Scion202's Avatar
Default 2nd Gen tC Wiring Diagram
This should be made sticky
Scion202 is offline
Old 07-14-2011, 12:31 AM
WellesleyScion's Avatar
Yes it should
WellesleyScion is offline
Old 10-18-2011, 04:48 PM
jtk2's Avatar
I'm sure its on here but I'm not sure which one it is.
On the driver side window switches. For the lights.
What color are the +/- wires for that?
__________________
jtk2 is offline
Old 10-18-2011, 05:42 PM
black, white, green and purple are the up down function wires. Beige and yellow is for the lock, so what ever wire is left is for the light.
Old 10-18-2011, 05:55 PM
jtk2's Avatar
There's black, white, tan, blue, green, yellow, and white with black stripe.
jtk2 is offline
Old 10-19-2011, 01:07 AM
goose_119's Avatar
but you cant tell me this wont help a lot of do it yourselfers
goose_119 is offline
Old 12-03-2011, 04:36 AM
RedDragons's Avatar
That wiring is provided by Directed Electronics (Clifford, Viper, etc) for installers doing car audio, video, alarms & remote starts. I use it nearly everyday at work and the only way to have access to it is to be a Directed Dealer.
You should feel fortunate this was posted for your guys as it is essentially all you need to install just about anything (short of performance products).
If you want some really legit wiring guides get Alldata, I have it for work and its the shiznit. And if you are truly good at wiring all you need is some know how and a DMM.
I posted one of these for xB2 thread.
RedDragons is offline
Old 01-12-2012, 07:21 PM
RedDragons's Avatar
FYI, the smart key wire colors are correct but will not work for remote starting. I will be trying some different wires next weeks on a RS7.
Do not use the wires listed for remote starting with smart key listed on this sheet.
Old 10-20-2012, 06:30 PM
fatty_gen2's Avatar
Where's the wire for DRLs?
Could it be the Headlight ones?
fatty_gen2 is offline
Old 10-24-2012, 02:43 AM
noskatehate22's Avatar
Does anybody know where exactly the data link connector is?
noskatehate22 is offline
Old 10-25-2012, 02:35 AM
russiankid's Avatar
If the data link connector is the OBDII connector that its on the left side at the bottom of the drivers knee panel. There is a little flip down cover for it.
russiankid is offline
Old 10-26-2012, 02:24 AM
Oh wow, lol I didn't even put two and two together and think about it being the OBDII port! Thanks!!!
Old 11-05-2012, 11:17 AM
TheDivineComedy's Avatar
What would I tap into and/or need to have the reverse lights and front parking lights come on when I unlock the car?
Would think just tap into the front or center dome lights but don't want the exterior lights to come on if I am driving and need to turn the dome light(s) on which would mostly be the front one. Would I even need to add a fuse if all said lights are LED?
Would this even be possible?
TheDivineComedy is offline
Old 02-27-2013, 09:26 PM
ajemptage's Avatar
Default Help with aftermarket HU install
Ok i know this is a extreeeeeeeeemly old thread but i need help and i can't find answers anywhere. Seeing as the original poster of this seams to have a wiring diagram i was wondering if someone could give me info on the steering wheel control plug wires for a 2011 tC.
I purchased a head unit that has a universal steering wheel control function, you tap into three wires and use the built in programming function on the unit to assign the keys to their respective functions.
The wires on the head unit are as follows:
Steering wheel GND
Steering Wheel Key 1
Steering Wheel Key 2
Any info would be great. I contacted the manufacturer but all they could say was that i need to make sure it is an "AD conversion" type setup as opposed to a CANBUS type. I have no idea what type my car is...
Thanks in advance everyone!
ajemptage is offline
Old 02-28-2013, 03:00 AM
fatty_gen2's Avatar
Originally Posted by ajemptage
Ok i know this is a extreeeeeeeeemly old thread but i need help and i can't find answers anywhere. Seeing as the original poster of this seams to have a wiring diagram i was wondering if someone could give me info on the steering wheel control plug wires for a 2011 TC. I purchased a head unit that has a universal steering wheel control function, you tap into three wires and use the built in programming function on the unit to assign the keys to their respective functions.
Steering wheel GND
try posting info on the head unit you bought. might help.
Old 02-28-2013, 12:06 PM
ajemptage's Avatar
Good point...
Its an Eonon G2103V
The info can be found here:
http://www.eonon.com/Car-GPS/2-Din-C...VD/G2103V.html
Any help would be much appreciated!
Old 02-28-2013, 09:09 PM
ajemptage's Avatar
I figured it out, so for anyone else who is looking for the same answer I will list it below, it uses the same pin-out as most Toyotas since 1980.
Anyway, the wires are as follows:
GRND is pin 6 if looking at the pin side of the 20 pin white connector,
Key 2 is pin 7
Key 3 is pin 8
I found the pin-out here:
http://www.castulucci.com/projects/c...ors/index.html
Thanks everyone!
Old 08-05-2013, 08:12 PM
JSICKNESS's Avatar
Lightbulb 2014 TC
I Finally Finished my Sub Install on my 2014 Scion tC (*w/o BeSpoke)
Here are the wires to use for a Line Output Converter
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
I did not have to splice/ Cut any wires
The LOC wires will fit directly into the back of the Pin input
(*in the back of the head unit)
____
JSICKNESS is offline
Old 08-18-2013, 01:28 PM
zaneregan2010's Avatar
Originally Posted by JSICKNESS
I Finally Finished my Sub Install on my 2014 Scion tC (*W/O BeSpoke)
Where did you tap into to get your remote wire to work?
_________
zaneregan2010 is offline
Old 08-18-2013, 05:44 PM
pfdumigan's Avatar
The blue wire with white stripe coming out of the 10 pin connector. Seems to be the best bet.
pfdumigan is offline
Quick Reply: 2nd Gen tC Wiring Diagram
