Scion tC 2G ICE & Interior In-car entertainment and electronics...
Amp remote please help
Old May 18, 2012 | 12:38 AM
mkeple's Avatar
Default Amp remote please help
Hey, I'm new to the forum and could use some assistance. Ive done some searching on amp/ sub installation and am having trouble figuring out which wire to use as remote. Ive tried both the white and yellow on the ten pin harness. White doesnt turn on, and yellow wont turn off. Can someone give me a hand? I dont have a tester andd hand and dont have the money to buy one this week. Btw I have a cement Tc2 and that ____ is pimp haha.
Old May 18, 2012 | 01:19 PM
r2d2michael's Avatar
can you look at a wiring diagram of the amp you bought> it should have came with one. also posting a pic of the wires comming out of the amp would help. on my sub the remote wire was blue not white or yellow.
Old May 18, 2012 | 02:13 PM
GQQSE13's Avatar
when you say the white and the yellow from the 10 pin ar eyou talking about from the head unit wiring kit?
Old May 19, 2012 | 03:57 PM
mkeple's Avatar
Hey thanks for the responses. I am using the stock headunit and according to the sticky for wiring I tried splicing into the white, stock amp remote wire and got nothing. When I tried the yellow "radio ignition" wire the amp turned on, but when I shut the car off the amp did not shut down. Now I am wondering if I should go through the minor trouble of using an in-line switch and finding a place for it or if there actually is a good spot to tap into that will shut down after I shut off the radio.
Old May 19, 2012 | 04:05 PM
mkeple's Avatar
Yes, I was refering to where on the stock wiring harness I should tap into for power. There is a plug that has ten slots and has all solid color wire coming out. On a few threads people mentioned using the white or yellow wires and seemed to have no problems.
It is my old amp setup with the regular blue remote.
Old May 24, 2012 | 05:54 PM
BBesco2021's Avatar
im sorry i didnt read any of the post so far but behind the radio, there should be a wire that is blue with a white stripe or even just a solid red wire. either of those two wires should do the trick.
Old May 29, 2012 | 08:08 PM
Jiggavolt's Avatar
Do you, by chance, have a 2012? I'm thinking the wire colors used between 2011 and 2012 are different, because I had the same issue as you. The white wire only outputs 6.2V switched (not enough to turn the amp on), and the yellow wire outputs constant 12V.
Try the red wire. It's 12V switched on my car and what I used for the remote.
Old May 30, 2012 | 07:00 PM
mkeple's Avatar
I know this is a bit late but I figured I should confirm incase someone comes across this in a search.. The red wire is the wire to use in the 2012 tc. And thanks jiggavolt for responding, even though it was a bit belated haha.
Old May 30, 2012 | 07:08 PM
Jiggavolt's Avatar
No problem, I just finished my own installation yesterday. Hopefully this post will help other 2012 owners in the future!
Old Jun 9, 2012 | 07:41 PM
clickclickw00t's Avatar
I put in an aftermarket headunit and I used the Amp Remote power to turn it on with the harness
Old Jun 19, 2012 | 10:49 AM
blktc2's Avatar
So is this the same wire for the 2011? Also, I saw on YouTube where someone tapped into the grey wire that feeds the 12v receptacle down behind the shifter, is that acceptable too?
Old Jun 19, 2012 | 08:29 PM
NickF127's Avatar
Any wire that turns on and off with the car is acceptable. The solid yellow wire is constant 12v power so it is not. The red wire on this harness works fine.
http://www.sonicelectronix.com/item_...a-70-1761.html
Old Jul 19, 2012 | 02:24 PM
blktc2's Avatar
Just looking for some clarification on the right wire to use for the remote amp turn-on on the factory harness on the 2011 tC. (Did it change on the 2012's? I assumed they were identical.)
I see 3 other threads that reference different things so I'm trying to find a definite answer on this:
https://www.scionlife.com/forums/showthread.php?t=214019&highlight=amp+remote
https://www.scionlife.com/forums/showthread.php?t=212027&highlight=amp+remote
https://www.scionlife.com/forums/showthread.php?t=201994&highlight=amp+remote
Sooo is it the red wire (pin 8 - power antenna) or the white wire (pin 9 - woofer amp) on the 10 pin power harness? Or do they both work? Sorry to be a PITA but I’m in the middle of an install and would like to get it right the first time. Thanks in advance!
Old Jul 20, 2012 | 12:46 AM
mkeple's Avatar
Red dude. And use those quick crimp connectors so if it is wrong or you wanna change it in the future you just remove it and tape over the break in the sheathing.
Old Jul 30, 2012 | 05:02 PM
blktc2's Avatar
Thanks mkeple. I thought I'd include a pic for future reference in case anyone else is confused on which wire to use for the remote amp on the factory harness.
Old Aug 6, 2012 | 06:44 PM
russiankid's Avatar
I used the yellow wire that runs to the cigarette lighter as my remote. Works perfect.
BlingSlade
Nov 20, 2015 06:56 PM
neneago
Oct 27, 2015 04:47 PM
Denzel
Oct 14, 2015 10:15 PM
DannyBoy65
Sep 21, 2015 06:23 PM
SJMiller
Sep 12, 2015 06:33 PM
