Scion tC 2G ICE & Interior In-car entertainment and electronics...
DIY Permanent, NON paper, door rattle fix.
Old 01-13-2012, 10:57 PM
Xander451's Avatar
Default DIY Permanent, NON paper, door rattle fix.
This is a permanent fix for the rattling in your door that will stop about 98% of the rattling and it only costs about 4 bucks.
Time to do: Approx. 5 mins per side
Materials needed:
-Scissors
-and this craft foam stuff from walmart:
Driver Side.
Step 1: Remove the window/lock controls
Pull up here, there is a hook at the other end that will break if you try to pull up there.
Then pull back to remove the controls.
This is that hook I was talking about.
Step 2: Cut strips of the foam sheet and place anywhere that is flat. (I used a black sheet of foam but you can use whatever color you want because it doesn't show once the controls are re-installed.)
This is how I did mine.
Step 3: Re-install the controls in the opposite way they were removed making sure that the hook at the forward end goes all the way forward before you snap everything down.
Congratulations! You've just silenced that annoying rattle and now you can enjoy your music as loud as you want with very very little rattling if any.
Passenger side installs the same way.
Xander451 is offline
Old 01-13-2012, 11:28 PM
MightyP's Avatar
Where did you find the foam?
MightyP is offline
Old 01-13-2012, 11:30 PM
Xander451's Avatar
I got it from Walmart in the craft section but I'm sure any arts and crafts type place would have it too.
Old 01-13-2012, 11:50 PM
biglilsteve's Avatar
I love it man. Nice DIY.
biglilsteve is offline
Old 01-14-2012, 12:23 AM
Xander451's Avatar
Thanks! As I get my hands on more parts I'll post more write ups
Old 01-14-2012, 01:30 AM
itscurtsk's Avatar
is it the rattling noise when you bump up the bass?
itscurtsk is offline
Old 01-14-2012, 01:33 AM
You don't even really have to bump it up. I would experience the rattling at very moderate volumes where I'd think to myself, "now there is no way my music is loud enough to be causing this!"
Old 01-14-2012, 03:28 AM
Xander451's Avatar
Yeah the music rattle not the window rattle that some people have been getting.
Old 01-14-2012, 04:23 AM
tyap's Avatar
Wow. Nice! Thanks for the post!!!
tyap is offline
Old 01-14-2012, 03:37 PM
StreetSweeper's Avatar
U should hear the back of my car....it makes all kinds of noise.
____
StreetSweeper is offline
Old 01-14-2012, 04:17 PM
Xander451's Avatar
Any ideas on where in the back the noise is coming from?
Old 01-14-2012, 04:20 PM
Yeah now that the door vibration is just about gone I can hear the back of my car vibrate when the JL hits.
Old 01-14-2012, 09:03 PM
pieceoflettuce's Avatar
Nice tutorial, I'm doing this atm, but I cant get the panel snapped back on...the side closest to the door wont snap back in??
____
pieceoflettuce is offline
Old 01-14-2012, 10:54 PM
Xander451's Avatar
Originally Posted by pieceoflettuce
Nice tutorial, I'm doing this atm, but I cant get the panel snapped back on...the side closest to the door wont snap back in...??
Pardon the french but snack the sh*t out if it abs if that doesn't work then take a sharp blade to the foam in that area and take off a thin later if foam.
Old 01-14-2012, 10:57 PM
Xander451's Avatar
Sorry about the typos, using my phone to respond and my auto correct sucks
Old 01-14-2012, 10:59 PM
Xander451's Avatar
For this I would suggest pulling all if the plastic panels off and use something like dynamat to dampen the vibrations.
Old 01-20-2012, 12:34 AM
CrispyFShacker's Avatar
Thanks a lot it worked great. My Walmart only had the huge pack so now I have tons of multicolor peel and stick foam . I do still get some vibration from one side you didn't place any foam I'm gonna take it off again and see if I can get a thin piece on that sodr
CrispyFShacker is offline
Old 01-20-2012, 12:43 AM
MightyP's Avatar
I bought the foam tonight and had the same thought. "Holy crap, I need about 1/4 of 1 sheet and I have 6 sheets???" Guess I'm gonna be foaming a bunch of stuff.
MightyP is offline
Old 01-20-2012, 12:55 AM
DaYUUM/Scion Evolution
KidJustin's Avatar
lol, foam the whole inside of ur tC2 for extra protection when u AutoX
KidJustin is offline
Old 01-20-2012, 01:16 AM
MightyP's Avatar
Just went out and actually did the mod. Works great. As clean as 6x9 speakers can sound!
But I lied, I didn't need 1/4 of the sheet. I needed about 1/32 (if that) of the sheet. As thin as you cut the strips, 6 sheets works out to miles of foam.
After you buy the pack for $4, don't just do your car. Do all your friends' cars! Do their friends' cars! In fact, do all the tC2s in the state with your foam!!!
MightyP is offline
Quick Reply: DIY Permanent, NON paper, door rattle fix.
