Scion tC 2G ICE & Interior In-car entertainment and electronics...
Driver door panel removal.
Old Sep 21, 2011 | 01:45 AM
Gen2yellow2's Avatar
Default Driver door panel removal.
Anyone have a walk through on how to take off the driver door panel? thanks.
Old Sep 21, 2011 | 03:29 PM
devanb3's Avatar
if someone doesnt ill do one up in the next day or two
Old Sep 21, 2011 | 07:22 PM
That will be awsome
Old Sep 21, 2011 | 07:51 PM
WellesleyScion's Avatar
***I am not responsible if you break stuff***
-Remove the silver door handle using the pry point on the bottom of it. remove the 2 screws behind the silver piece.
-Pop the panel behind the door handle, unscrew the 1 screw behind it.
-Remove the side view mirror sail on the door
-Pop the entire door panel off starting at the bottom and working around the whole interior piece
Install in reverse order.
Old Nov 7, 2011 | 03:12 AM
Ultimaniac's Avatar
You will notice white or green plastic pins when you remove the door panel. Some are likely to stay in the frame of the door when they pop loose, instead of coming out with the plastic paneling. When reinstalling the panel onto the frame, make sure you have all the pins in the paneling (and none in the frame) when popping it back into place.
Old Nov 7, 2011 | 03:13 AM
VVTinme's Avatar
http://oemaudioplus.com/images/Insta...F-20110726.pdf
Pages 15-16, if anyone else finds this thread and wants/needs pictures.
Old Nov 14, 2011 | 02:12 AM
Druidiron's Avatar
^^ Great find! It doesent get much easier than that.
Old Feb 2, 2012 | 07:09 AM
12stormtroopertc's Avatar
AWESOME! I was wondering how the hell I removed my stock 6 x 9's! Prevented me from dynamating my door because I didn't have the patience to figure it out at the time. Thanks.
Old Feb 2, 2012 | 09:49 PM
DE5PA1R's Avatar
Is it necessary to remove the panel to replace the fabric? I can't find that info for the tc2.
Old Feb 5, 2012 | 02:58 PM
DE5PA1R's Avatar
If anyone's wondering:
If you don't want to cover and tuck, the answer is yes. The fabric is wrapped onto a second panel inside the larger door panel. You'll need to break 10 or so plastic pins to detach it, then pull off fabric, reupholster, and glue or screw back in place.
lunchbx05
May 7, 2015 06:42 PM
idriveanxa
Mar 8, 2015 12:03 PM
Joeynenj
Nov 25, 2014 05:29 AM
McG_XB
22
Feb 10, 2004 09:53 AM
oj411
Dec 27, 2003 05:51 PM
