Factory head unit RCA voltage output and impedance?
Anyone know what the RCA voltage output and impedence is for the factory head units in the TC2? Mine is a 2013, though I assume it is the same for all of them.
The RCA's on the rear of the deck are only low pass anyways, If you are planning anything other than hooking up a sub amp your going to have problems.
If your concerned with high volts into your amp most GOOD amps will take at least 2.5 volts with no problem and 4 volts with increased distortion.
As for the off shore stuff I have run .25 all the way up to speaker level inputs with the same results.......crap.
MadSciontist_xB
05-10-2015 06:28 PM
TheSilencerTC
Scion tC 2G ICE & Interior
02-24-2015 04:56 PM
lunchbx05
12-11-2014 06:13 PM
