tC2 Wiring Information
I have access to Directechs, Directed electronics wiring information, and figured I would share all this for all the other DIY guys out there
Remote start, security, keyless entry, accessories
Item / Wire Color --- Polarity --- Wire Location
12volts / white(120 amp)---pos---dash fuse box, white 1 pin plug, pin 1
second 12volts / white(30amp) yellow(5amp)(without smart key only)---pos---ign switch, white 8 pin plug pin 7 and 2
starter / green---pos---ign switch, white 8 pin plug pin 8
second starter / beige---pos---ign switch, white 8 pin plug pin 1
ignition / gray---pos---ign switch, white 8 pin plug pin 6
second ignition / gray---pos---ign switch, white 8 pin plug pin 4
accessory / black---pos---ign switch, white 8 pin plug pin 3
data bus / lt blue(rx) beige(tx)---data---transponder amplifier, black 7 pin plug pins 4,5
can bus / high lt green---data---data link connector, white 16 pin plug pin 6
can bus / low white---data---data link connector, white 16 pin plug pin 14
power lock / beige---neg---driver kick, white 18 pin plug, pin 15
power unlock / yellow to pink---neg---driver kick, white 18 pin plug, pin 16
lock motor / red to beige---5wire---driver kick, white 18 pin plug, pin 9
driver unlock motor / black to lt green---5wire---driver kick, white 18 pin plug, pin 18
passenger unlock motor / blue---5wire---dash fuse box, white 48 pin plug (2c) pin 12
parking lights - / purple---neg---headlight switch, white 20 pin plug pin 18
parking lights + / blue---pos---dash fuse box, white 48 pin plug(2a) pin 12
hazards / white---neg---dash fuse box, white 48 pin plug (2c) pin44
left turn signal / yellow---pos---dash fuse box, white 24 pin plug (2a)pin16
right turn signal / gray---pos---dash fuse box, white 24 pin plug(2a) pin 5
headlight / blue---neg---headlight switch, white 20 pin plug, pin 20
reverse light / red---pos---driver kick, harness to rear
left door trigger / white---neg---dash fuse box, white 24 pin plug (2a) pin 4
right door trigger / grey---neg---dash fuse box, white 56 pin plug (2d) pin 52
dome supervision / black---neg---dash fuse box, white 8 pin plug (2f) pin 6
trunk/hatch pin / black to gray---neg---driver kick, blue 13 pin plug pin 5
trunk/hatch release / green to white---neg---driver kick, blue 13 pin plug, pin 7
factory alarm arm / blue---neg---driver kick, blue 12 pin plug pin 11
factory alarm disarm / green to red---double neg---driver kick, blue 12 pin plug pin 12
tachometer / gray---ac---data link connector, white 16pin plug pin 9
clutch pedal / yellow(in), red (out)--- +N.O. --- clutch switch, black 2 pin plug, pins 2 and 1
fuel pump / lt green---pos---dash fush box, white 24 pin plug (2a) pin 13
rear/mirror defroster / black---neg latched---rear window defroster switch, grey 20 pin plug pin 2
speed sense / blue---ac---radio, white 20 pin plug pin 3
brake wire / blue---pos---dash fuse box, white 40 pin plug (2b) pin 7
parking brake / black---neg---dash fuse box, white 48 pin plug (2c) pin 19
horn trigger / blue---neg---dash fuse box, white 48 pin plug (2c) pin 16
left window (up/down) / black-white --- a --- power window master switch, white 18 pin plug pins 10 and 12
right window (up/down) / green-purple --- a --- driver kick, white 18 pin plug, pins 2 and 11
sun roof (open/close) / green-beige --- neg --- sliding roof control switch, white 5 pin plug pins 3 and 4
Audio wiring
12v / blue---pos---radio, white 10 pin plug, pin 4
ground / brown---neg---radio, white 10 pin plug, pin 7
ignition / yellow---pos---radio, white 10 pin plug, pin 3
illumination / gray(parking light) / blue(dimmer)---pos/neg radio, white 10 pin plug, pin 10 ; white 6 pin plug pin 5
amp turn on / white---pos---radio, white 10 pin plug, pin 9
power antenna / red---pos---radio, white 10 pin plug, pin 8
left front speaker / pink/purple---pos/neg---radio, white 10 pin plug, pins 2 and 6
right front speaker / lt green/blue---pos/neg---radio, white 10 pin plug, pins 1 and 5
left rear speaker black/yellow---pos/neg---radio, white 6 pin plug, pins 2 and 6
right rear speaker / red/white---pos/neg---radio, white 6 pin plug, pins 1 and 3
aux audio input left / white/black---pos/neg---radio, white 20 pin plug pins 17 and 16
aux audio input right / red/black---pos/neg---radio, white 20 pin plug pins 15 and 16
left subwoofer (6x9) / yellow/black---pos/neg---woofer amplifier under driver seat, white 10 pin plug pins 1 and 5
right subwoofer (6x9) / red/white---pos/neg---woofer amplifier under driver seat, white 10 pin plug pins 2 and 6
Scanners broken, and that was fun to type! lol. Hope this helps some people out
Audio wiring
And i gathered all of this information from directechs.com, and although they are usually right, ALWAYS double check your work with a meter or some type of tool to make sure your tagging into the right wiring.
I hold no responsibility for what you do with this information and if you break stuff. make sure your doing it right, and if your not sure how to test, bring it to a Pro!
Administrator
Administrator
umnitza
10-31-2015 07:32 PM
