tC2.5 window switches on tC2?
I know the tc1 had auto up/down for both the driver and passenger side, does the tc2.5 have this function as well? I've only seen specs stating this function on the driverside only. In any case, is the tc2.5 window switch compatible with the tc2? Would it be a simple plug and play?
A quick search on Scion's website states that the 2.5 only has drivers door auto up/down.
I also searched the scion website and saw that it was for the drivers side, just wanted to verify from an actual tc2.5 owner.
It is only drivers side auto up/down, just got my tc 2.5
Thanks for the verification Arsenic. Does anyone know if the switches are interchangeable?
They should be, get one from the dealership and check it out. However, correct me if I am wrong, but wouldn't you need to change the window regulator (motor whatever its called) to allow it to go and up and down automatically?
an OG....Scion202 (ScionEdge) did it. check his thread, i dont remember if he said how but u can see that its been done
