2011-____ [ANT20]
Big Bird 2012 tC RS 7.0 #41 Build Thread (Super JDM Shifter YO!)
Old Jan 24, 2012 | 08:12 PM
Scion202's Avatar
its 50 degrees out!
Old Jan 24, 2012 | 08:15 PM
fun173's Avatar
Originally Posted by Scion202
its 50 degrees out!
I need more time to think
Old Jan 24, 2012 | 09:12 PM
WellesleyScion's Avatar
Paint the engine cover and battery tie down yellow and get a yellow shift ****. Dont think, just do...
Old Jan 24, 2012 | 09:54 PM
fun173's Avatar
Yellow shift ****, yes. Where and what will fit?
Painted engine, No.
Old Jan 25, 2012 | 01:23 AM
Scion202's Avatar
less arguing....more modding
Old Jan 25, 2012 | 02:10 AM
KidJustin's Avatar
DaYUUM/Scion Evolution
paint everything yellow
Old Jan 25, 2012 | 02:18 AM
dm1336's Avatar
Won't be big bird without some yellow wings. Upgrade that spoiler!
Old Jan 25, 2012 | 02:43 AM
Scion202's Avatar
turn off the ECO haha
and dont forget to put premium gas in it. dont believe it, ask Ted
so does the intake sound like $200?
Old Jan 25, 2012 | 03:00 AM
fun173's Avatar
Never!
I love the spoiler! I chose black because I think it goes well with the rims, mirrors, grille and a pillars. However, I do like the cleverness of your post.
I put 89 in it. Can't turn off Eco unless I step on it?
I think the intake is absolutley worth $200.
Old Jan 25, 2012 | 03:22 AM
fun173's Avatar
Just got reminded of my old car byt the "Cleopatra" build thread so i thought i'd post a pic of it.
1997 Subaru SVX
Old Jan 25, 2012 | 04:02 AM
Scion202's Avatar
scroll through odometer/ mpg/temp. when you get to Eco just push in the pin and hold. no more stupid green light!
91 at least!
Old Jan 25, 2012 | 04:10 AM
fun173's Avatar
91 at least!
Thanks. Does turning it off have any effect on MPG or is it just a BS light. And what does 91 do for the car? Doesn't it take 87?
Old Jan 25, 2012 | 04:19 AM
Scion202's Avatar
Light turns off when you exceed whatever RPM they set. that's it. stupid phukin useless ****
takes 87! but with premium gas you have a more controlled combustion plus its has less crap in it cuz its higher octane(like more flamable) so everything burns off.....
Result:
Car feels much quicker, the VVTi kicks in faster
Car sounds better
Car feels more solid cuz there is less combustion related vibrations
Lotta ppl on here will call BS on everything I said. Just try it and be prepared to be blown away. Me and Ted had a long convo about this. After using 93 for a while and fueling up with 87 the car simply feels sluggish
Old Jan 25, 2012 | 04:42 AM
fun173's Avatar
Alright, I'm going to let the tank run low then next time I fill it up I'll try it with premium.
Old Jan 25, 2012 | 01:38 PM
carben100's Avatar
Result:
Car sounds better
I'll just call BS on some of the stuff you said
-Premium gas doesn't have less crap in it/will not burn cleaner, the additive package is usually the same between grades (the gas station you go to affects this way more than the grade of gas)
-I highly doubt it sounds any different
-The only reason there would be additional vibration with lower grade gas is if there was knocking, which should not happen since the car was designed to run on 87 octane gas and the ECU would retard the timing to avoid knocking anyway
-If the ECU is also designed in such a way that it can advance the timing past the normal point for 87 octane gas, you would see an increase in power with higher grades because higher octane gas requires more energy for detonation (the cause of knocking)
Summary: use what ever grade of gas makes you happy and if the ECU can adapt to make better use of it, it will.
Old Jan 27, 2012 | 03:57 PM
Errikos's Avatar
hey where did you get the engine cover from?
Old Jan 27, 2012 | 04:02 PM
fun173's Avatar
Ebay. It was just a one time thing though and i got it for $55 luckily. Save a search and there's bound to be more sometime soon.
Old Jan 27, 2012 | 04:14 PM
Errikos's Avatar
thanks ill keep my eyes peeled because 115$-130$ ehh not feeling it found it on a toyota parts website http://www.trademotion.com/parts/201...iagram=8522247
Old Jan 27, 2012 | 04:50 PM
fun173's Avatar
Yea, I was shocked I got it so cheap. I had set my high bid up to like $85 and still did not expect to get it.
Old Feb 5, 2012 | 02:25 AM
Scion202's Avatar
bump while I look for answers in ur thread
